SOURCE: how much rinse aid do I put in my dishwasher and
The dispenser will take about 6 oz of rinse aid if completely empty. It will only need filled every couple months depending on how often you do dishes.
If you are getting poor drying performance or spotting use a rinse aid that is called 'Turbo Dry'.
The arrow is how much rinse will dispense each load. Start out near the center, if you see spotting or turn it up slightly and try another load.
SOURCE: put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
SOURCE: dishwasher sending out bubbles
There is a plastic strip that runs between the lower panel and the upper panel you can pull the strip off then take the outer panel and cardboard out you will see the rinse dispenser there. open the door and take the rinse cap off the dispenser and push all of the plastic tabs in at once and pop the dispenser out. now you can clean out the dispenser and put things back together.
SOURCE: Kitchenaid KUDS02 Rinse Aid dispenser does not work
I don 't know how to fix the dispenser; however, there is a jet dry product that is sold in stores that is in solid form, you just clip it to the upper rack. I have seen it in Wal-Mart in the detergent aisle.
SOURCE: Dishwasher rinse-aid dispenser not working
the film is caused by hard water. go to www.dishwasherfilter.com. they have a product out for this exact problem. works amazing every time and is very affordable.
Good Morning friend, thank you for your post!
I see that you are having an issue with your rinse aid dispenser not adding rinse aid into your Frigidaire dishwasher. You may need to run hot water into your dispenser to help clear out any dirt or clogs within your dispenser. If that does not help I would recommend making sure the water temperature inside your dishwasher is at 120 degrees. If the water is not at the correct temperature it will not allow proper dispensing of the rinse aid. You may also want to check the filter at the bottom of your dishwasher to assure that it has been cleaned out and is not distributing dirt or debris inside of your dishwasher. I would also recommend checking the spray arms to make sure they are not dirty and spray water evenly. You can clean them out using a pipe cleaner. I hope this information is helpful to you. -Matt
