Question about Maytag DWU9962 Dishwasher
Bottom Washer Arm Problem
The bottom washer arm stops turning and is very stiff when turned manually. We've taken it apart and cleaned out the inside, this works but it is happening all the time. If we don't wash our dishes before putting them in the dishwasher. We never used to have to do this. Is there a part (food grinding/clearing) that we need to replace? Thanks for any help you can give!
  • 640 Answers
Lift the arm off there should be a washer that the arm sits on,that washer may be missing or worn out.when you have the arm in your hand do you see bearings?if not try to find a washer the diameter of the arm and install it before you put the arm back on.
Posted on Aug 19, 2007
SOURCE:
Bottom water arm won't spin easily so the dishes are not getting clean. How do I fix it?
You did not post the make and model number but there is a thin nylon washer that wears out on those and that washer needs to be replaced. You should not need any special tools to get to it.
Mar 04, 2016 | Dishwashers
-+the top arm is not turning in my washer Model #GU1200XTLB2. I have removed it and cleaned it and it is still not turning. Can you offer any suggestions? Thank you,
Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
homeguides.sfgate.com > Foreclosures > Other Foreclosures
Remove the lower tray of the dishwasher to freely access the spray arm. ... Although spray arms are directly powered by the water pump for the dishwasher, not all of ...For best use, clean the filter and pump at least a couple of times per year. .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell Your ...
Dishwasher Cleaning - Top Rack Doesn't Clean - YouTube
? 12:57
https://www.youtube.com/watch?v=75DB9cyPYO0
Feb 7, 2013 - Uploaded by Dogwood Tales
With that said, I'm working on more such videos for household maintenance and repairs and ... In my case the bottom rack of thedishwasher was cleaning well, but the top rack of thedishwasher was not coming out clean at all. In fact ..... How to clean and replace Dishwasher Spray Arms - Duration: 2:07.
How To Fix A Dishwasher Not Cleaning Bottom Or Top Rack ...
Jan 12, 2016 | Dishwashers
Bottom washer arm doesnt turn, the arm gets caught.
I think that this may solve your problem. Watch this video on youtube.
Dishes not clean How to Clean dishwasher
Oct 18, 2014 | Dishwashers
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
Bottom of my Bosch dishwasher not cleaning dishes, top tray OK have cleaned / taken apart
Carefully inspect the lower spray arm for a crack or separation.
Also inspect the holes in the spray arm that may be stopped up with debris.
Remove and clean the filter in the front center of the tub.
Set the spray arm at the 12 o'clock position and start the washer. After 30 seconds open the door and check the position of the spray arm. Do thi several times to confirm the spray arm is rotating.
Feb 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a Bosch Dsihwasher - model SGS53A. The lower washer rota arm is not turning. I have checked that water outlets are not blocked in the arm - all clear. The up arm turn normally. Steve
arms rotate by water volune and pressure / ck to see if the screen in bottom and the cup sreeen is clean . if not clean it with a stiff nylon brush reinstall and try it again // also ck water level if too low this would cause problem .. float or pressure sw causes low water . or water valve filter screens .. hope this helps let me know .. **** .
Dec 04, 2009 | Washing Machines
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Washer arm is all clogged up.
Hi Bob: The center of the arm screws out, is it the top or the bottom? I have a Maytag as well, once you unscrew the center piece the arm shoul come off, there will be a clip in the center, all you do is depress the tabs along the side and pull out. The bottom is similar as well. I hope this helps.
Apr 19, 2009 | Maytag DWU9962 Dishwasher
Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
Sep 29, 2007 | Kenmore 24 in. 17362 / 17364 / 17369...
Hi Karen P The bottom arm ( well all arms really)is rotated by the water pressure created by the main pump. The bottom arm should spin freely when rotated by hand. If not, then the bush (or plastic bearing) may be worn or sticking. These parts are fairly inexpensive (at worst a new bottom arm will be required). Contact your local Maytag spares supplier and ask for a Bush repair kit for the bottom arm of your model. Regards
Aug 20, 2007 | Maytag DWU9962 Dishwasher
Dishwashers Logo
77 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
