Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
Printer offline i have dpr1260 with HP 1018 connected, OS is winxp, firmware of dpr1260 is 1.21, it shows printer offline, even if i give a print command - nothing is printed. My second printer of epson works perfect behind dpr1260, also HP1018 works fine when connected to PC straight. I need your expert advice
  • 4 more comments
  • john khan Aug 20, 2007
    Yes! port numbers are as you have specified.
    DPR1260 wizard does recognize the printer. Wireless was setup first. I have also checked setting: Netbios over TCP/IP, Bidirectional Printing,Advanced printing features,UPnp and SSDP are automatic and started - still HP1018 is shown by DPR1260 and control panel of winxp as offline, it doesnt print.
    Interestingly My second printer Epson c43 is working perfectly behind DPR1260
  • jnpowell Nov 18, 2007
    I'm having the exact same problem (have the HP 1018 too). One interesting I'm finding is that if I connect the printer to my computer via USB, and print something out.... then connect the printer to the DPR-1260 print server, the status of the printer appears as "on-line" and I am able to wirelessly print... until I turn off the printer. Then I would need to do the whole setup again to get it to work.
    I have no problems what-so-ever with my other printer, an Epson RX500.
  • drsuna Dec 20, 2007
    I hooked up DPR-1260 to my wired network and its received its ip via DHCP from my router right away. Update FW from 1.12 to 1.21, reboot then reassigned a static ip. Turned off the wireless option as I don't want to use that at the moment, as where I plan to put the printer/DPR-1260 has an ethernet port. Reboot the DPR-1260 after all that and hook my always on HP1018 to USB1 and ran the setup wizard from DPR-1260 and printed the test page successfully. I turn off the printer, unplug DPR-1260 and brought both of them down stair to hook them up to their final position.
    When I tried to print again, my documents isn't printing and keep staying on the queue and no error/msg reported. Now I notice that 'Offline' on the title of the queue as well as in the DPR-1260 setup page.
    These are the things I tried:
    Turn off bidirectional
    Turn on NetBIOS in TCP/ip
    Tried LPR instead of RAW.
    I'll try hard reset
  • john khan Dec 14, 2008
    To golf14_kmitl
    Tks! Atleast with firm upgrade now dpr1260 shows HP 1018 ready. But doesnt take any print command.
    With firmupgrade 1.24, HP 1018 is now shown as ready but doesnt take any print command
  • rmdean Feb 09, 2009
    I have this same problem. I set the unit up without too many issues, and I have been able to get it to work with my HP laserjet 3030. I am using Network Magic to manage my home network so it is easy to monitor whether or not the DPR-1260 is ONLINE or not. I can use it no problem for intermittant periods, then suddenly, it goes OFFLINE and the only thing I can do to change this is to go into the basement and power cycle this unit. I have 1.24 firmware. I have not ever been able to scan, but it works fine WHEN IT WORKS which is frustrating.
Ok, i solved linking the printer with the application provided with the dpr, PS-link, its added a new port and printer and works fine since. hope helpfull
Posted on Jun 10, 2011
Upgrade firmware to v1.24
Posted on Dec 06, 2008
Just use LPR printing. This was the only oiption for my HP Laserjet P3005
Posted on Jul 22, 2008
I had the exact same problem, and fixed it by unchecking the bi-directional printing (see item 3 by zt3000).
Posted on Nov 19, 2007
  • sblanchard Nov 19, 2007
    Ignore my previous comment. It didn't work for long. :(
    Scholar:
  • 76 Answers
1) Ensure you've run the D-Link supplied automatic configuration wizard. 2) Also ensure you have "Netbios over TCP/IP" enabled in your network settings. 3)Ensure you turn off "Bidirectional Printing" in the Ports tab and "Enabled Advanced printing features" in the advanced tab, for testing purposes. I know the printer connectivity is officially supported by D-Link (thru an independent 3rd party test facility) but it seems they may have had NetBeui installed, which is an outdated networking protocol. Try the first 3 options I gave, if they don't work, then let me know. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
  • 2 more comments
  • Stevie Wonderboy Aug 19, 2007
    I'm assuming the "not helpful" neg you gave means the 3 options I provided didn't affect your situation??
    Okay,
    I'll need a little bit more feedback on what you are experiencing and have/haven't done in order to give you the solution. Groping in the dark is not that fun.
    Just know that the raw TCP printer port numbers for your dpr1260 are such.
    USB1 = 9100
    USB2 - 9101
    USB3 = 9102
    USB4 - 9103
    Can we assume the router's internal printer automatic configuration wizard does not recognize the printer when you go thru the steps as noted on page 22 of the user's manual, AND that you setup the wireless portion FIRST (as instructed by the manual)??
    ZT3000
  • Stevie Wonderboy Aug 20, 2007
    Since you have the latest firmware, the only thing left is to hardware reset the router.
    I've included a couple screenshots of my setup to a print server. Normally I'd use the 9100 etc ports but I just didnt do it this time.
    If the hardware reset doesn't work, then there is an unsolvable hardware conflict.
    ZT3000
    2nd screenshot
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
"Printer offline"
I would go onto
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=5070121#N305
Go ahead and download the firmware update and follow the directions. Hope this helps. Let me know!
Jan 31, 2014 | HP Photosmart 7510 Wireless e-All-in-One...
Prinder show in control pannel but if iam give print command then printer show offline in control pannel. i does not give printout
Turn off the printer.
Disconnect the printer and unplug it from power.Do the same with the PC.
Reconnect them after a while.
Turn the printer on and start the PC.
Make sure the usb connections are well fixed.
Now print.
Hope this helps.Thanks!
Oct 10, 2011 | HP DeskJet D1460 InkJet Printer
In my hp 1018 blank print coming when i give printing command
The printer may be offline. To get it out of that state. Try following these steps.
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Feb 04, 2011 | HP Office Equipment & Supplies
HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
May 06, 2009 | HP LaserJet 1018 Printer
My HP laserjet 1018 doesn't work
first of all remove the power cable and rmove the usb connection or  parallal connection from the pc. Then conneted the power and usb cable. you need to open the case to remove the printer cartise. and add the cartise. Start your pc. give print command.
Jan 23, 2009 | HP Hewlett Packard LaserJet 1018 Printer
Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
Jul 28, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Hp laser jet 2600n
firstly ckeck the data cable is connected in your pc or not
in your pc go start setting printer and faxes and in this window you can show your printer
then ckeck it it is ready or not
if it is ready then open the printer clj 2600 and ckeck the few command pending or not if the command is pending then concle it and then give printouts
if the printer is offline then goes printer properties and ckeck printer properties
Jul 12, 2008 | HP Color LaserJet 2600n Printer
HP LP1020
ok, y solved linking the printer with the application provided with the dpr, PS-link, its added a new port and printer and works fine since. hope helpfull
Sep 12, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
3,728 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
