I have a 2005 honda foreman 400 when in automatic if i try to take off slow it bogs out. It works fine in standard and if i take off fast in automatic. I have replaced the clutch and reprogramed the machine but still have the problem. Anybody have any suggestions?
Hello
it seems that the control motor may be sticking to lock, and/or the angle sensor is bad or causeing this. something to check is the control motor shaft lock. on the left side of the atv there is an electric motor that is bolted to the front crankcase. take the two bolts that hold it on, off. and remove the motor. take a short screwdriver, and you should be able to turn this shaft freely either way. if you cannot nudge it a little the one way it may be stuck and see if this frees it up. if this was stuck and gets freed up. this may just be a temporary lock, but if it continues the angle sensor may need to be replaced.
if the motor shaft was not locked up then the angle sensor may still be to blame. thank you.
I have exactly the same problem with my 2004 Honda 400 auto. Clutches were replaced within 400km and now problem is back again. Very frustrating as bike only has 1252 km.....scouts honour!!
