FixYa.com
Tags:
IBM ThinkPad X41 Tablet PC
Battery light stays on even after comp is turned... (by 2 users)
posted by Totek on Aug 19, 2007
1. I try to turn on my computer after it goes into Stand By mode but it doesn't. The screen is off but there are 3 lights flashing to show its on. Its like only part of the computer is responding.
2. And then recently, I noticed that the battery light is still on when I unplug it and my computer is turned off or is in Stand By mode and the worst is the light is still on when the computer is off. Its not like its slow at responding and turns off the light later on, it stays on. I take the battery out and the computer is really hot even though its been off for an hour.
3. I've been getting a lot of those "blue screens" saying it can't reboot properly and it restarts but it doesn't progress. I just reimaged my computer and it just gave me the "blue screen" when I tried to use my computer.
Is this an internal problem? Is it because I've been using an older battery charger at times? I checked the output voltages and they are the same. The new one is just lighter and smaller...
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 10, 2008
The battery light stays on even when the power cable is unpluged. I replaced both the planer bord and the battery, the problem is still not resolved. WHAT CAN I DO TO FIIIIIIIIIXXXX this?
Segun Olubi.
Best Solution
posted on Aug 19, 2007
Thanks for Trying (70)
atlasuk2007
Rank:Wiz Wiz
Rating: 79%, 51 votes
hi,
sounds like you need to replace your hard drive, blue screen of death means 2 things bad memory or hard drive
regards
Rating Locked! (?) Totek has rated this solution as Thanks for Trying
Can you Help with these Tablet PCs problems?
Tablet PCs
sounds and audio device
shah92 rank: Wiz Solved:74 Answer This...
Battery Light
The battery light stays on even... Answer This...
multimedia audio and video...
please help! I can't find... Answer This...
I bought a used thinkpad i am...
I bought a use thinkpad and I... Answer This...
Access IBM Button not working
Access IBM Button is not... Answer This...
Repair Service
Find Tablet PC Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
