Question about RCA DRC8335
Not able to scan stations
Im trying to schan all of my stations over to the rca unit, but only one comes up.I've tried selecting air and yes, air and no cable and yes and cable and no. I am hooked up to direct tv and i am able to see one station while it is scanning.the book says if the challel list comes up empty make sure the rf cable if properly connected. the setup that i used didn't use a rf coaxial cable.
  • 38 Answers
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Posted on Jan 27, 2008
SOURCE:
Im trying to set up an RCA antenna on my Hisense TV and can't get the channel scan feature to come up. What do i do?
Are you on a t.v channel or an input? Many t.vs won't access channel scan if you have one of the inputs currently selected. Once on a channel activate the channel search feature
Oct 29, 2016 | RCA Televison & Video
I have a hdmi rca tv, unhooked the digital cable box for awhile went to hook it back up and can't get any channels scanning picks up nothing what should I have the setting set to? Hdmi set to cable
If you have a cable box the channels are selected via the cable box remote and the TV is set to an HDMI video input. The specific input is identified where the HDMI cable connects from the box.
Use the video input remote to select the HDMI for the cable box.
Scanning is for identifing the over the air stations that use the coax input noted as antenna (ANT IN) on the back of the set.
Hope this helps?
Mar 13, 2016 | RCA Televison & Video
I have a RCA L32WD22. When I push power on, the green light comes on then goes amber and the TV shuts off. Takes about 4 seconds and never get a picture.
I would resolder the inverter chips about five of those on the inverter board first. If that doesn't fix it, try the Power Supply unit (PSU), order this capacitors http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
or better if you can get a new PSU altogether, but doubt you can find one right now.
Oct 27, 2011 | RCA L32WD22 32 in. LCD HDTV
My newly purchased RCA L26HD35D will not got to a station by pressing numbers...! Tried to dial in 02 to 09 ~ get blank page. The only way I can change stations is by using scroll...! I like the set,...
U getting a free DTV air broadcasting signal by using a antena?Yes,tries press button on the remote chanels like 2.1, 4.1, 4.2, 4.4, 5.1, 5.2...to 9.1 so on,will get all those digital chanels right away.
Oct 13, 2010 | RCA L26HD35D TV
I've hooked up my dvd player to my rca television
Did the dvd Play? if yes, Maybe you have to select in the VIDEO mode on your t.v. not in the CHANNEL Mode. Because you cannot watch video in channel stations unless otherwise you have RF tuner. or the rca plug is faulty???? Try another rca
Mar 20, 2009 | RCA Televison & Video
Setting radio stations on clarion auto dbr2475 w magi-tune
try this on most units search the station that you want to save and when its on it press and hold the numbered buttons till it says on the display saved or you hear a tone
Jan 07, 2009 | Clarion Car Audio & Video
DRC8335 not picking up channels when scanned
make sure you have tuner as input---if you are running through another unit as I am to get the signals to the tv--I have to select vidio1 as input to be able to see the screen. My guess is that input is not set to tuner.
Hope this works.
Oct 12, 2007 | RCA DRC8335
RCA DRC8335 Logo
218 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
