When first turned on, it states: "no space for db. please delete more than 4.0mb", then freezes when you try to get past the "artist" (or other) option. also, i'm completely unable to manage my mp3 on wmp anymore. states: "it is not possible to change sync settings at this time. try again later." i've lost the manual and don't even know how to reset my mp3, never mind tackle this. can u help me?
wmp shows mp3 playr full xcept 14mb, but also says there are no songs on this device at this time.wmp shows mp3 playr full xcept 14mb, but also says there are no songs on this device at this time.
when i tried to plug my rca mp3 player into my computer it keeps saying unknown device.. at first i figured it was my driver so i re installed it. nothing happened then when i went to turn it on it says RCA and freezes i hve lost hope sombody help me when i tried to plug my rca mp3 player into my computer it keeps saying unknown device.. at first i figured it was my driver so i re installed it. nothing happened then when i went to turn it on it says RCA and freezes i hve lost hope sombody help me
AnonymousFeb 18, 2008
Hola: mi prblema es que borre las canciones que origalmente traia mi MP3 y cuando intente encenderlo aparece en ingles "ningún espacio para db. Retira más de 4.0mb", entonces se bloquea al intentar superar el mover "artista" u otra opción y ya no se que mas hacer. por favor responder a [email protected]Hola: mi prblema es que borre las canciones que origalmente traia mi MP3 y cuando intente encenderlo aparece en ingles "ningún espacio para db. Retira más de 4.0mb", entonces se bloquea al intentar superar el mover "artista" u otra opción y ya no se que mas hacer. por favor responder a [email protected]
AnonymousMar 26, 2008
I have the same problem kind of. When I bought the device it had songs already programmed into it. When I brought it up on my windows media player, the songs wouldn't come up. I've tried trouble shooting but for some reason nothing is able to bring the songs up on the computer so that I can delete them. Did you ever find out how to fix it or is it a glitch and unfixable? Email me @ [email protected] if anyone has an answer. I have the same problem kind of. When I bought the device it had songs already programmed into it. When I brought it up on my windows media player, the songs wouldn't come up. I've tried trouble shooting but for some reason nothing is able to bring the songs up on the computer so that I can delete them. Did you ever find out how to fix it or is it a glitch and unfixable? Email me @ [email protected] if anyone has an answer.
Reformat the device
plug into the usb on ur cpu
open windows explorer and find the removable
disk
right click the device and goto format
do fat32 dont do qiuck format
load songs and enjoy
I have had the same mp3 player, and it usually showed up as an item in My Computer. It stopped showing up this way and I had no way of accessing/changing files. I solved it by using the player's menu to "Restore Default Settings." It doesn't delete the songs in memory, but it did solve this problem!
my samsung yp-q3 is saying the same message i have deleted all music and tried resetting and it still does not work, i am using a macbook with it and it has not cause me any problems untill today , any advice ?
In order to create the media library database for your device to work properly, there needs to be at least 50MB of free space. Just delete a few songs and try again.
You could also use easyRip's Device Info module to switch to MSC mode if you have addition MTP conflicts
(Either way, you do need 50MB of free space on your device for it to power on and create the db properly)
Hi sir
You Can Download Free MP3 From Youtube By This Site : video2mp3.net If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
For Windows XPTM users, you are connecting the device in MTP mode to the computer by default. You will need to set the device to MSC mode, so go to the device menu\Settings\Advanced\Protocol = > Press Play/Pause key to select MSC mode which will appear as such on the screen. Reconnect the device to the computer, and you can now see those files and delete them. DO NOT forget to set the device back to MTP mode when finished, so go to device menu\Setting\Advanced = > Select MTP mode.
I think the problem is that you deleted one of the syst. file on the RCA Lyra.. These are the files you need to have in order to make the mp3 player work.
Setting.dat Music.sec Time.dat music.lib
and the 4 folders (Voice) (line-in) (FM) (audible)
is there a reset on the player?? mine has one.
if not, connect to computer, and open icon for player, right click and format the player.
reload the music then
rca s10 series
What happens if it doesnt let me put more than 1 song on it at a time?
I have several albums on this mp3 player but it also says "no songs" why?
