Question about SanDisk Sansa e260 MP3 Player
HELP ok i have tried 2 update the firmware on my e260 but after it was done it said to go to recovery mode so i fallowed the steps and nothin happend i have tried it over n over yet nothin helps so if anyone knows wats goin on then HELP
    Problem Solver:
  • 12 Answers
What happens when you power on the player? If just the blue ring lights up and NO screen activity, and you've already tried the recovery mode (hold switch, hold REC, power on) then you need to send the unit back provided that it has been purchased within the year. Unfortunately the only software tool where you can hook up a unit and have the software force flash it to a repaired state is a sansa connect. The e2xx series does not have any assistance/repair software available for download. I know that this isn't a technical solve but technically you can't fix this as it's solid state technology. So please don't flame me for helping. I got a "no help" vote because they had a dead MLB on a PC. Thanks in advance. (RMA# support is 1-866-726-3475)
Posted on Aug 23, 2007
  • Kevin Flynn
    Kevin Flynn Aug 23, 2007
    In case our recovery procedures differ:
    ALL DATA WILL BE LOST WITH THIS PROCEDURE!!
    You can try a ROM recovery.
    - TURN OFF UNIT
    - Place hold switch so orange shows
    - Hold down the REC button with the red dot on the side of the player.
    - Whilst holding the REC button, press the power button as if to turn on the unit
    - Let go of the REC button
    You should see the recovery console.
    YOU WILL LOSE ALL DATA!! However you will also have a working player.
  • Kevin Flynn
    There's hope! http://www.anythingbutipod.com/forum/sho...
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Why won't my computer recognize my sandisk player.....i just plugged in the usb cable directly in the computer....but it's not being recognized.
For the Sans e260, see the e200 series support site on "not recognized":
http://kb.sandisk.com/app/answers/detail/a_id/266/kw/recognize/r_id/101834
Solution 1 RESETTING THE DEVICE
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
When RESETTING the player did NOT help
Solution 2
GOING TO MSC or RECOVERY MODE and next UPDATE FIRMWARE
STEP 1 GOING TO MSC MODE or RECOVERY MODE
For e200v1/e200R (Recovery mode only): Connecting in Recovery mode
For e200v2 (Force MSC mode only): Enabling MSC mode
Check your firmware, see the differences on next link:
http://kb.sandisk.com/app/answers/detail/a_id/193/related/1/session/L2F2LzEvc2lkL0NqNGJpNVBq
STEP 2 FIRMWARE REINSTALLATION OR UPDATE
ALL DATA ON THE PLAYER will be ERASED !
Method 1: Automatic, using the Sansa Firmware Updater
Method 2: Manual, downloading firmware from the Sansa Forum
For e200 series version 1 and 2 to the Forum e200 thread
For e200 series version Rhapsody to the Forum e200R thread
Dec 10, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 will not power up
Okay what you do for this is hold down the power button for 20-25 seconds or so. This will reset your Sansa e260 and then it will power up like normal. I have had this problem before. If that doesn't work then I don't know what will.
Feb 02, 2009 | SanDisk Sansa e260 MP3 Player
My sansa e280 mp3 player stopped working i dnt knw y
I'm unable to assume the exact problem with your mp3 player as you've bluntly said that the device is not working. Try the following steps and that should work. If not let me know:
  SOLUTION 1 - Reset the device
Resetting the Sansa View/Fuze
Resetting the e200/c200 series
SOLUTION 2
 - Reload and update to the latest firmware
STEP 1 - Enable MSC or Recovery mode
Enable MSC mode on e200v2 / c200v2 / Fuze
Force Recovery mode on e200v1 / c200v1 / e200R / View
STEP 2 - Update to the latest firmware
You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware
Sansa Fuze firmware update
Sansa View firmware update
Sansa e200 series firmware update
Sansa c200 series firmware update
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??)
 2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer   3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC   4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on).  5. Try other modes as well.
Keep the device in AutoDetect Mode and follow the instructions below:
i. Connect your Device
ii. Right click on My Computer and select Manage
iii. Select Device Manager
iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
v. Right Click on the device and select Update Drivers
vi. Select 'No, not at this time' and click Next
vii. Select 'Install from a list or specific location' and then click Next
viii. Select 'Don't search, I'll choose the driver to install' and then click Next
ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use
Jan 31, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
Snasa e260 wont load up
Hi. Your Sansa E260 might be encountering some system errors and would need a Firmware re-flash by setting it to its recovery mode. Try this: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again. I hope this helps. The E260 is a great player.
Apr 10, 2007 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
Please refer to: http://www.fixya.com/support/t114495-format
Mar 24, 2007 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
Hi Alina. Seems like oyur Sansa E260 is experiencing some system errors. Here's a procedure you could try -- it's setting your player to the Recovery Mode and re-flashing its firmware. I hope this helps: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try steps 1-4 again
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
