Question about StarTech.com (USB1100S) Network Adapter
USB1100S adaptor Help I need to load this software on my computer and I only got a small disc. I need this fast
  • 12,061 Answers
The small CD will/should work in a normal CD/ DVD? Just place in center it in the tray. This can B a problem tho if'n ya CD DVD is set Vertical.. like some I have had.. I have also got around this issue by getting access to a PC that I can use and copy the small CD to a Normal one.. or a USB stick etc, and put that on the PC that ya weren't able to use the Mini-CD on. There isn't much on the 'net these links may be OK.. www.driversforwindows.com/startech_usb1100s_driver_8748.htm www.driversforwindows.com/o/
Posted on Aug 19, 2007
SOURCE:
Laptop keeps turning off
backup important docs, then format hdd, install win, and drivers and software
Jan 24, 2014 | Fujitsu Siemens Computers & Internet
I have Print Perfect Platinum and cannot open the file to load the program as there is no setup on the first disc. Help Help
HI,
You can try putting the disc in your drive, go to my computer ,click on the drive you have the disc in. This should open the disc for you to load. Good Luck. ( By the way I am not a computer wiz,)
Jun 03, 2010 | Cosmi Print Perfect Platinum
Help with my Bell and Howell BH-10
You should have had a cable come with your camera; one end would plug in to your camera with a small square end, and the other end would connect to your computer. The computer end would be a standard USB end. You should have also received a disc in your box that had software to load onto your computer. Once that software was loaded, you would plug the camera in. Your computer would recognize the camera and startup the software. A box would open and it owuld give you a choice of things to do. Usualy it would give you thumbnail views of all of the pictures in your camera and ask if you wanted to copy only some of the pictures over to the computer, or all of them. It would also allow you to delete all of the pictures from your camera.
ddddddddd
If you go to either of the following websites you can download the software you need.
http://www.bioticaindia.com/bh-10.html
http://members.driverguide.com/driver/detail.php?driverid=
76886&action=summary&from_ums=1
That should do it.
Apr 07, 2010 | Bell & Howell BH-10 Digital Camera
Adaptors
Hello
You need "D-26 Adapter"
Compatibility of KODAK EASYSHARE Docks
Best regards,
Zizzler
Apr 22, 2009 | Kodak EASYSHARE G610 Thermal Printer
Microsoft FSX will not load on my new Vista PC
Hello hshames,
The game requires Windows XP SP2, or Vista..So that should not be the problem.
First install the latest version of Direct X which you can download FREE HERE.
Below is a small summary of what may be causing your installation problems.
This seems to be a problem some users are having.It seems to be either software related (other software not the actual software on the FSX disc itself), or hardware related (DVD drive not reading the disc properly).
To try solve this issue, follow these steps in order. If the problem is solved after step 1 (for example) you do not need to follow the instructions following that step. if not solved, move to the next step in the chain.
1. Some DVD readers can take up to 2 minutes to detect disc #2 (for reasons unknown). If the disc appears not to be detecting, just leave the computer for a few minutes and come back and check. Some users have reported that the disc #2 finally detects and installs correctly several minutes after inserting the DVD into the drive.
2. Manually browse the Disc #2 file contents in either Windows Explorer, or by accessing the DVD through the "My Computer" option and check the files on Disc#2 are actually different to those on Disc #1.
3. If you have the hard drive space available, copy the contents of both DVDs to a temporary folder on your hard drive, and install the product from the hard drive copies.
4. Read this Microsoft Tech article and follow instructions > http://support.microsoft.com/kb/290301
After trying the above suggestions, please post back with the status of your problem and any new info so I can be of further help.
Thank you for choosing Fixya!
Apr 05, 2009 | Microsoft Flight Simulator X for Windows
Message saying put disc into xbox 360
1. Turn off your XBox and unplug all cables from the console and the wall, including a wireless adaptor if you have one.
2. Clean off your game discs using a non-scratch cloth.
3. If your game discs are already scratched, you can most likely take them to a video game store, such as EB Games, and get it cleaned for a small fee.
4. Plug your cables back in, except for the wireless adaptor or network cable (ie. don't connect to the internet).
5. Start up one of your games and see if it loads.
6. If it loads, turn off your XBox, and connect to the internet.
7. If it still does not load, it may be a disc drive problem in which case, contact Microsoft XBox 360 support at: www.xbox.com
Dec 28, 2008 | Microsoft Xbox 360 Console
Loading Wireless G Network Adaptor
which OS u r using ......if its vista then there might be compatibility issue...vista is facing huge compatibility issues......try wid XP........
Apr 16, 2008 | Microsoft Office Outlook 2003 for PC
JBL Creature 2 Blowing Fuse
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
Open Questions:
See all StarTech.com (USB1100S) Network Adapter Questions
StarTech.com (USB1100S) Network Adapter Logo
135 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
Ekse
Marvin
Marvin
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
