Question about Baby Care
Graco lovin hug swing
The keypad on our graco swing has stopped working. I ordered a new motor unit from graco and we still have the same problem. The swing will start if it is plugged in buit stuck on one speed. The other speeds or sounds cannot be selected nor do the on/off buttons work. To turn off the swing it must be unplugged from the wall.
SOURCE: Graco swing not working, I'm trying to open the motor box.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Posted on Nov 20, 2009
  • 286 Answers
SOURCE: Need instructions for Graco-Windsor 6-speed
hi
i think these are correct
http://download.gracobaby.com/ProductInstructionManuals/ISPS030AA_ISPS032AA.pdf
Posted on Oct 24, 2010
  • 13 Answers
SOURCE: My 6 speed Graco swing will not work. The motor
It sounds like the problem is in the motor. Because of the heavy load on the motor during normal swing operation the brushes that are attached to the communicator are wearied out. This causes a loose contact between the brushes and communicator and the motor is loosing his power. Ideally, I would replace the motor. The only a problem is that the available replacement motors have a short shafts, when the motor used in Graco swing has a very long shaft. So, there are two solutions: buy a new motor sage from Graco for $28; OR buy a new motor ($5-$7), then carefully remove a nylon end cap from the old motor and replace it with the nylon cap from a new motor (WARNING: you have to be careful when doing this, because if it will be done inappropriately the brushes can be easily damaged)
Posted on Feb 11, 2011
jyackle5
  • 8197 Answers
SOURCE: i can not find the
You can get the manual on the link below.
http://download.gracobaby.com/ProductInstructionManuals/PD118655A.pdf
Posted on Apr 29, 2011
Does the Graco Duet Soothe have a fuse? Im hoping that is why this stopped working.
It has a plug. The swing also uses batteries if it's not plugged into the wall. You can also order replacement parts from Graco's Website.
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 10, 2017 | Graco Baby Gear
How to disassemble graco swing
First, take part the seat. It had buttons and what not so undo them and take it off the frame. 2nd: Take the mobile (where the teddies hang) part by pulling. From there you just pull things apart. You shouldn't need any tools.
I hope this helps a little.
Apr 27, 2012 | Graco Lovin Hug Swing - Erin
I bought it and put new batteries in it and the music will play and i press the buttons to make it swing and it doesnt do anything. It doesnt make any noise like its trying to swing or nothing. Could that...
Graco swing motors are known for going bad, sorry. I have had no luck trying
to fix them as you tear them down and the electronics are what has gone bad.
They have a motion sensor in them along with a complicated motor to swing swivel
that if you lose a small ball that is the interface, you are doomed.
Time for a new one and if you buy one at a garage sale be sure to run it with weight in
it for at least 5 minutes. That culls out the bad motor ones!
Feb 05, 2011 | Graco Baby Gear
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Same problema as described by other person: Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Oct 19, 2010 | Graco Toys
Graco swing not working, I'm trying to open the motor box, but can't get the last screw out, which is behind the swinging attachement.
Nov 15, 2009 | Graco Baby Gear
Baby Care Logo
277 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you a Baby Care Expert? Answer questions, earn points and help others
