Question about Motorola TalkAbout T5530 2-Way Radio
FLUENT COMMUNICATION THEY WORK BETWEEN 12 KM BUT THEY ARE NOT CLEAR YOU HARDLY HEAR ONE ANOTHER. WHAT SHOULD I DO.ISIT POSSIBLE TO CONNECT THEM TO MY COMPUTER THROUGH INTERNET
  • 91 Answers
Dear sir,
u can coonect the same via IP camera , u will have to open ip camera & find pre ampmlifier section for both inward & outward voice communication , then only it is possible or use Voice over IP routers , which has audio in & out port ,with some modification to walkie talkie handsfree
Posted on Jun 10, 2013
Co222 '03 Trailblazer
C0222 and C0226 The corresponding wheel speed sensor signal is less than 6 km/h (4 mph) for 5 seconds, or 120 seconds in order to set both DTCs.
Did you perform the ABS Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - ABS
  1. Use a scan tool in order to clear the DTCs.
  2. Operate the vehicle at a speed greater than the specified value.
Does the DTC set?
19 km/h (12 mph)
Go to Step 3
Go to Diagnostic Aids
  1. Turn OFF the ignition.
  2. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  3. Disconnect the wheel speed sensor connector.
  4. Use a DMM in order to measure the resistance across the wheel speed sensor.
Does the resistance measure within the specified range?
700-10,000 ohms
  1. Spin the wheel by hand as fast as possible.
  2. Use a DMM in order to measure the AC voltage across the wheel speed sensor as the wheel spins.
Does the AC voltage measure greater than the specified value?
100 mV
Go to Step 5 yes
Go to Step 8 no
8
Replace the wheel speed sensor. Refer to Wheel Speed Sensor Replacement .
Did you complete the replacement?
5
Inspect for poor connections at the harness connector of the wheel speed sensor. Refer to Testing for Intermittent Conditions and Poor Connections and to Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 10
Go to Step 6
Aug 11, 2015 | Cars & Trucks
ABS indicator lamp lights up and indicator km(in speedometre) is not lit
try pulling battery for ten minutes or so and see if that clears any of the codes if not use a obd11 code reader and that should give you a correct answer
Apr 22, 2014 | 2011 Ford Ranger
What does code 1670 mean on 04 suzuki verona
p1670 is a communications error between abs module and ecm- ecm does a communications check in first 5 seconds of cycling key from off to on/start. Can be affected by other modules on network, possible causes include but are not limited to bad abs module, wiring, connectors, terminals in connector, chafing of wiring,possible software issue. Recommend clearing codes and waiting for it to become a hard code( sets code EVERY time key is cycled on ) in order to pinpoint- very elusive problem unless setting a hard code
Read more: http://wiki.answers.com/Q/What_does_the_code_p1670_mean_on_a_2004_Suzuki_Verona#ixzz23yPPUPCs
Aug 19, 2012 | 2004 Suzuki Verona
Make Epson Photo RX620 print wirelessly
This model printer has only an USB connection.
It is possible to print wireless by connecting the printer to your computer and sharing your printer on your network that is connected to a wireless router.
OR connecting your printer to a wireless router that has an USB port for connecting a printer.
Aug 04, 2012 | Epson RX620 All-In-One InkJet Photo...
The download from camera quit working
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 28, 2012 | UClear Bike Helmet Communicator
A bicycle travels 12 km in 40 min. What is its average speed in km/hr?
18 km/hour
The bike is traveling at the speed of 12/40 = 6/20 =18/60
18 km/60 minutes
Jun 21, 2011 | Computers & Internet
I was on-line yesterday and the terch had me try making changes to clear Imaging Units Needs Replaced - Now I Have An Error Code C12C0
This is a hard disk error. When we were troubleshooting yesterday you said you were going to try and disconnect some sensors to by-pass the problem with the Image Units. Did you put them all back? This hard disk error states that it can not communicate with the built-in hard disk.
Jim
Preston Computer Services
www.prestoncomputerservice.com
May 20, 2011 | Kyocera Mita KYOCERA/MITA - KM-C3130...
How do u set up a cobra 148gtl 40 channel to here far away
hello there firstly you will need to raise your antenna has high as possible and buy a preamplifier this will raise the weak stations and give better signals hope this helps
Mar 20, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
SX700 and T5522 talkabouts
Hello Walvis,
Based on a quick web search the Motorola SX700 appears to be a Family Radio Service unit for use in the USA and the Motorola T5522 appears to be PMR446 radio for use in the UK. While the radios are similiar, they don't operate on the same frequencies so they won't be able to communicate with eachother. Because both FRS and PMR446 are very similiar, Motorola often markets versions of the same radio (with slightly different model numbers) for each service.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Motorola Talkabout SX700 2-Way Radio
Motorola TalkAbout T5530 2-Way Radio Logo
37 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
