SOURCE: Rusted external mounted antenna
If its a "fixed" non adjustable antenna, just sand it down with steel wool and wipe it with silicone once in a while to keep rust off. If there are two "flats" on a conical base, most times it can be unscrewed and replaced. Antennas that slide in and out or electric antennas cannot be removed this way.
SOURCE: small leak in fuel line
A fuel line leak is not a laughing matter and no short cuts should be taken and this can lead to other serious issues. If you fuel line is leaking you should replace the line all together. It is HIGHLY recommended that you do not drive the vehicle until you get it replaced and the chance of fire is extremely high at this point.
As for the antennae it is always best to go with what the factory has installed in your vehicle.
