Question about Kodak EasyShare V610 Digital Camera
Kodak V610 Easyshare won't turn on
Even when fully charged and attached to mains my lovely V610 lights up for a second, makes a whirring noise and closes down, all lights go out. I have recharged battery, used mains only, taken out battery disconnected and left for 5 mins, restarted - still same result."Beep, Beep Whirrr" - CLOSE DOWN
Hi I have the same problem with my beloved V610. Have you solved the issue thanks
Posted on Feb 25, 2015
  • 78 Answers
You have a board power supply issue which would be covered under warranty. (Hopefully you still under warranty)
Posted on Aug 31, 2007
Okay.. I Turned The Camera Off To Let It Charge Over Night. When I Came To Turn It Back On, It Wont Power On. When I Put The Charger Back In, It Lights Up As Though It Is Still Charging But It WILL NOT...
Haha,maybe there's a accident happened at the night ,so the battery for Kodak EasyShare V610 is still charging as begin.You need let it charging until it is full with power then we can confirm what's the problem definitely.
Feb 10, 2011 | Kodak EasyShare V610 Digital Camera
Error message E45 comes up on camera - What can I do to fix it? Kodak easyshare V610. Message comes up when camera turned on. Batttery charged etc.
Is the lens extended? If so, try hitting the lens a couple of times with the palm of your hand and then turning off the camera. Turn it back on and let me know what happens. Sounds crazy I know, but those things are notorious for that error and that problem. You can also try taking out the SD card and see if the error goes away. Let me know what happens. Thanks.
Jeff
Nov 23, 2010 | Kodak EasyShare V610 Digital Camera
My Kodak easyshare M853 want charge.Itworked fine til I let it sit or a while now it want charge. Can you please help? I tried A NEW USB CABLE THE LIGHT FLASHES BUT ONLY FOR FEW SECONDS.I HAVE TRIED 2...
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 30, 2009 | Kodak Easyshare C813 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
When i turn on my Kodak EasyShare C913 Digital Camera it makes a werid sound and turns itself off. whats making it do that? and how can i fix it?
It is probably your rechargeable batteries are not holding their charge and therefore the camera is not receiving enough power to start. The whirring would be the camera lense attempting to open. When it can't get enough power it will automatically shut off.
As a first step try removing the batteries and replacing them with completely new ones. Make sure they are fully charged.
If this doesn't sort the problem out it may be something more serious which would probably require a technician to look at it.
Nov 16, 2009 | Kodak EasyShare C913 Digital Camera
V610 camera wont turn on
I figured out that the rechargeable battery inside my camera is dead so I have to buy a new one because it is like 3 years old.
Mar 06, 2009 | Kodak EasyShare V610 Digital Camera
V610 KODAK ERROR E45
This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Dec 04, 2008 | Kodak EasyShare V610 Digital Camera
Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Nov 24, 2008 | Kodak EasyShare V610 Digital Camera
Kodak Easyshare Z760 orange light flashing
The flash does not charge separate from the rest of the camera. Try cleaning the flash sensor on the front of the camera or the flash led may be bad.
Secondly, this light functions as a flash sensor which is trying to tell you that you need to use a flash although you may have the flash manually turned off. looks like a bolt of lightning with a circle/slash through it.
May 09, 2007 | Kodak EasyShare Z760 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
266 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
