-   I also keep getting this: "..."failed to start because smv.dll was not found"" problem, and notify you when a new solution is offered. -   Guest
Apr 01, 2009
-   yep i have the same problem - just started since the last time i ran the s/w (approx. 4 weeks ago). I am runnning on XP.-   Guest
Apr 01, 2009
-   I also have the same problem. Does anyone know if you can delete Plus3 and go back to Plus 2 that came with the E10? -   Guest
Apr 01, 2009
-   i have the same problem and it's giving me the s%&@s. no matter how many times i reinstall it doesn't work and now I can't load any new songs onto the player :-(
This seems to be a fairly recently problem people are having.. maybe it's to do with a recent automatic windows update or something?! -   Guest
I had the same problem. When uninstalling, check "yes" when it asks you if it should delete the library database file (it will say to check "no" if you plan to reinstall; ignore that). If that doesn't work, try downloading iriver plus 3 from the the international version of the iriver website: http://www.iriver.com/index.asp
Please uninstall your iriverplus 3 from your computer and download and install the latest version from www.iriver.com The latest version addresses this problem. Sorry for the inconvenience caused.
Comments:
Apr 02, 2009
- I tried the solution and did not fix the problem.
Apr 02, 2009
- ok - here's the drum ... click on plus3 and make sure you are downloading v3.5.5.2 which fixes the problem.
Iriver E10-cant delete old files, wont show up on laptop but player says 'usb is connected' there is...
(More)
Iriver E10-cant delete old files, wont show up on laptop but player says 'usb is connected' there is a dodgy file called fooool.exe. possible trojan?
iriver will not open, autoplay has been stunted somehow. Suspect file has been deleted somewhere...
(More)
iriver will not open, autoplay has been stunted somehow. Suspect file has been deleted somewhere along the line. Need to know a) how to fix it or what to replace and b) how to access it enough to transplant a file. examples of error messages "cannot copy to iriver, the path is too deep"
How do you open the e10 to change the battery? I've got the screws out ok but the two sections don't...
(More)
How do you open the e10 to change the battery? I've got the screws out ok but the two sections don't want to come apart.Is there something else I need to do
