Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Jenn air single wall oven model jjw8530BAB - exhaust fan not working properly
The exhaust fan seems to start working when the oven reaches a warm enough temperature....but, you can hear it whine up and down as the oven cooks in fact, when you think it should be on to exhaust the heat and cool the oven down AFTER the cook cycle is done, the fan is noticeably silent and obviously off. We think this is a problem but not sure what component is causing the issue. I cannot seem to find any related issues on any forums so I am hopeful someone here at FIXYA has some guidance/ideas.
  • 2 more comments
  • thefaders Aug 19, 2007
    ok - I located a metal probe (back left towards top inside oven) and a round 'screen' on the top of oven in center) thermometer or thermostat. I'm not sure what I was supposed to do once I found it anway.
    Any other ideaS?
  • thefaders Aug 22, 2007
    ok..I am with you so far - I will try and remove that item and see if any wires are burned/worn.
    One new thought is that the fan seems to turn off when the temp gets higher than a certain temperature (whereas it does seem to properly come 'on' when it first begins to warm up).
    Does this signify anything with it being 'temperature' driven (a thermostat issue vs. a control board issue)?
  • thefaders Aug 24, 2007
    the oven is 5 years old
    frankly the oven is a total piece of crap but we're not in a position to swap it out for new yet. It's one of Jenn Air's finest which had the defective door hinge issue (well-publicized). We finally had someone fix that to the tune of $150 last year so we have enough invested in the current one to seek inexpensive ways to fix this current issue.
    I'll plan to tinker with it this weekend to see what I come up with the wires.
  • thefaders Aug 26, 2007
    I've pulled the probe/thermometer out and noticed no burned or disconnected wires.
    The oven seems to function the same as described previously even after pulling this part out and putting it back in place.
    What's next?
  • 640 Answers
In not sure but i think that fan runs off a thrmistor that goes to the contol the oven door and look on the right side of the oven see if theres a metal looking bulb.
Posted on Aug 19, 2007
  • 1 more comment
  • anthony james
    anthony james Aug 20, 2007
    thats the thermostat bulb.if there are no other sensors inside the oven compartment the thermostat might also be controlling the fan.if you can trace where that bulb goes to see if any wires/boards look burned.i will try to find a schematic for you.
  • anthony james
    anthony james Aug 24, 2007
    still looking for a schematic.there has to be a probe to turn that fan on and i said it could be sensed by the t-stat,if you find where the wires run to (like the control board)either the probe is bad or the old is the oven?
  • anthony james
    anthony james Aug 27, 2007
    did that part connect to a board?see if you notice any other wires coming off the board.look for a plug with just 2 wires in it and unplug them.if that is the only thing that you removed and it was connected to the board your control board is bad.
I have an older jenn air model ww30430 and I cant get the fan to turn off or the upper oven to work. any suggestions
if your unit is switch position is the upper heating element is have convection? you cannot turn off the fan,but if your unit have separate option to choice the other option to oparate separately the upper heating element this one can be use.
Dec 24, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Error message on JJW9530DDS Jenn-air wall oven is 4d21
no/low cooling fan rotation (No RPM) single cavity or upper oven - check connection at cooling fan if ok, replace blower - DO NOT REPLACE CONTROL
Mar 06, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
We do not have a manual for the jenn air wall oven JJW8530BAB. we just hant to run the clean cycle but can't figure it out. anyone know how to set it to clean? sigmawolf
Actually I did not solve the problem as I'm just looking for a manual for the wall oven so I can set the clean cycle. I just can't see joining a service for just one manual.
Dec 16, 2009 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air wall oven control panel not working
my jenn air wall oven controls are not working how do i fix it
Nov 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
327 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
