Question about Motorola Mobility RAZR V3
Display won't light up
I haven't dropped the phone...one day I used it and it worked fine...a couple of hours later went to use it and the keypad light up but the screen doesn't...I've taken battery out..But still does not work...I can still make calls..just have to know what # to put in..
  • harleysangel Aug 19, 2007
    i fixed mine...removed battery and lighty pressed on the back of the screen where the battery rests..works fine now
You can fix the off screen by opening the top part of teh phone (4 tiny torx screws under the rubber gommets) and re-seating the flatcable connector. dnt forget a little glue on the gommets, or you wil lose them later. worked for me :)
Posted on Aug 19, 2007
SOURCE:
I have a 2000 Volvo s80 t6 it was running perfectly fine 2 days ago yesterday I went to leave and the gear shifter would not shift out of park, a couple hours later in tried it again and it worked, it was...
sounds like the solenoid or the relay that locks the lever into park when the key is turned off may be playing up just to check try using the spare key see if you get the same problem hope this helps regards mick
Feb 28, 2015 | Volvo Cars & Trucks
1995 miata cranks but won't turn over
Possibly the fuel pump or crankshaft sensor
Oct 20, 2012 | 1995 Mazda MX-5
I have the same problem. It's and LCD Problem
when u changed the LCD Flex Wire the 1st problem was solved righte?
Jul 21, 2009 | Sony Ericsson K850i Mobile Phone
My screen on the cellphone is white.
i have two of them take the phone in an have the company fix it or take your battery for 2 hours and put it back it and turn it on.
Mar 31, 2009 | Cell Phones
Nokia n95 8gb
i think after all that you should replaced the mainboard
Oct 20, 2008 | Nokia N95 Cellular Phone
1995 Chrysler Concorde
the alarm is activating when he locks it and for some reason the key or fob isnt deactivating it..check the disarm switches in the door
Aug 11, 2008 | 1995 Chrysler Concorde
APPLE IPHONE DEAD ZONE? ON KEYPAD 4 5 AND 6 WONT WORK (AND EVERYTHING ON THAT LEVEL!)
Try switching the phone off for a couple of hours. I had the same problem and tried everything, until I went to the movies and switched off the phone. When I came out and switched it on again it was working fine - incredible but true!
Mar 16, 2008 | Lands Phones
Phone LCD is very dull after water damage, rest of phone works
go get a torx screw driver and open it up stop turning it on that will only hurt it ... once you open it up dry under a lamp for a day and it will probably work
Aug 16, 2007 | Samsung SGH-T519 Cellular Phone
Motorola Mobility RAZR V3 Logo
159 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
