Question about Canon NP 6551 Black and White Copier
NP 6025 printing Crooked
I have a cannon 6025 when I use the sheet feeder the copies are comming out Crooked. Is there any adjustment for this. Thank any one that could help. Al
    New Friend:
  • 16 Answers
Yes ther is ! first clean the glass with Mr Sheen(which is a spray on furniture polish) the glass needs to be slippery so the paper slides nice and easy over it.Then if that doesnt help,where the feeder attaches to the machine are 2 hinges one of which you should be able to adjust. Hope this helps.
Posted on Aug 22, 2007
SOURCE:
When pages come out of the copier the image is printed crooked. The paper comes out straight, so feed is correct. Image is just crooked? Why?
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 25, 2016 | Ricoh Aficio 2018D All-In-One Laser...
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Digital replacement for Canon NP 6025
"No" is the answer to all of those questions, and even if it were "yes", purchasing a good quality refurbished digital machine from a reputable supplier, would still be a far cheaper option than all of that.
Not in or around Toronto, are you?
Mar 12, 2009 | Canon NP 6551 Black and White Copier
Lost copy code on Canon NP 6025
firstly IN SEQUENCE press 'ADDITIONAL' button then 'ID' button following with 'STOP' button and at last 'ADDITIONAL' BUTTON back...then it will appear whether ID code wana be activate or not.! u can try it....
Jul 23, 2008 | Canon NP 6551 Black and White Copier
It can be reset, but you may have to fix the problem first. And what is the problem with the copier, is it a 6025 or6551?
Jul 15, 2008 | Canon NP 6551 Black and White Copier
Canon 6025
Your problem is most likely caused by dirty optics. Place a sheet of paper on the glass & make 1 copy with the lid up. Look under the glass at the mirrors on the scanner & see if there is any dust on them. If so,turn the copier off & unplug it from the wall, remove the glass & wipe off the mirrors with a DRY cotton rag. There are 3 mirrors on the scanner assy. There is also three mirrors under the lens cover that should also be cleaned. After cleaning the optics, make a test copy.If your copies are still to dark, press the additional functions key & select exposure adjustment. You can lighten/darken all copies by changing this setting. If you have any problems or questions my email is bspier@carlsonsupplies.com Good Luck!!
May 29, 2007 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
117 people viewed this question
Clive
Clive
old marine
old marine
