Need instuction book keep saying error e2
Plug off the mains. Drain off the water by lowering the drain hose behind the machine into bucket or low level drain. Could be a panel in front of machine. Screws maybe underneath panel.
You will see the pump assembly right in the center with big black hoses.
You need a pair of pliers and a shop-vac if you have one, or towels and a bucket. Use the pliers to unscrew the pump filter, it is white in colour. When you unscrew this water will start to leak out; use towels or shop-vac to mop up. Do this till all water is mopped. Remove the drain trap completely, you will find much junk; clean out completely and refit carefully, in reverse order.
From the filter the hose goes to your pump, check this out you may find something blocking the impeller, remove any foreign matter. Refit everything in carefully.
Http://www.haier.com/products/product.asp?proID=10341
This is the link where you can download a manual, I think the error codes are generic, the other links for washing machines dont seem to work
Mart
