Question about Eureka Whirlwind 4383 Upright Vacuum
Has no suction
Belt is not broken, vacuum has no suction on powernozzle or hose
I just went through the same thing.  Your fan or impeller is probably broken off the shaft and no longer on the motor shaft.  My local repair shop wants $9 for the impeller and $29 to replace it. You will have to take the thing apart and put on a new fan or impeller blade and I'm still trying to do that to my vac.  I think I will have to heat the nylon impeller with a hair dryer to get it onto the shaft and then tighten the left hand nut. My vac is held together with torx screws so add a torx screwdriver to the price if you don't have one and want to do the job yourself.
Posted on Oct 25, 2007
SOURCE:
Hose setting, no suction through hose but not clogged. floor setting still works
The hose setting may not be actually selecting the hose.
Sep 23, 2018 | Hoover Vacuums
No suction
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Mar 30, 2014 | Kirby Ultimate G Bagged Upright Vacuum
No suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
No suction when vacuuming, but suction is good when using hose
check for blockage from where the hose sets in its
holder to the roller brush. Also see if the brush is
turning, the belt maybe broken.
Tom
Oct 22, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
No suction at the twirling brush
take a coat hanger and clean out under ...take off the brushes theres a small tunnel gets stopped up..
Sep 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction/Brush not working
Hi there SmartAlec from NelsonVacuums.com.au here.
There are a couple of common reasons that your electrolux vacuum cleaner would appear to have lost it's suction. The first and most common is that it has actually broken a belt. If the belt is broken the brushes won't spin and it will not pick up dirt. It is easy to test simply turn the vacuum on, release the handle (as if you were about to vacuum carpet) and lift up the head and see if the brushes are spinning. If not i can supply you with a new belt.
If the brushes are spinning then your next most likely cause is that there is a blockage in the vacuum somewhere. Test this by turning machine on and checking the suction at the hose (as if your were going to vacuum the couch) if it is poor then remove hose and fish out blockage. If it is ok you may have a blockage between hose and the brush of the vacuum.
If it is neither of these problems i can trouble shoot over the phone if you live in Australia 0269215200 or by email [email protected]
Happy Vacuuming.. :)
Aug 25, 2009 | Electrolux EL5010A Bagged Upright Vacuum
No suction
You have a clog somewhere in the vacuum. Check the hose and the little trap door on the underneath side of sweeper.
Does the brush turn? If not, then the belt that drives the brush is broken. Replace the belt
Jim
Jun 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
No suction on my vacuum. Hoover Tempo
try to clean between the roller and the tube to the hose
May 05, 2009 | Vacuums
Kirby G4 without suction
change your belt, if there is suction from the hose, and you cant see any blockages in the area where the brush roll is then you need to change the belt, even if it isnt broken. putting your hand over the nozzle to feel the suction is not the way to tell if it has suction.
Oct 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Eureka Whirlwind 4383 Upright Vacuum Logo
175 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
