Back to:
Tags:
Metz Mecablitz 60CT4 TTL Flash
Metz 60CT4 and VPS rated at 100ASA (by 2 users)
By Duke - usenet poster
I just shot my first med. format wedding.  I still used my 35mm to be on
the safe side. It was an outdoor wedding and the VPS III rated at 100ASA
had good exposure.  The indoor shots using my Metz set at F8 and 100ASA
overexposed the film.  I had densities around 35 according to the
density scale my lab uses.
What was I doing wrong?
I have a Mamiya 1000s so I have to shoot at 1/60 sec. when using it with
my stroboframe bracket.  I also use the reflex bounce card on my Metz.
The lighting was even; it just gave off more light than I needed.
Do I need to rate the VPS III at 160 when shooting indoor?
Kelan Griffin
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 16, 2008
Hello I have a Nikon N90s and a Mamiya 645 AF will this flash work as TTL in both camera's in autofocus. I am in need of a dependable flash I am looking at buying ct60-4 and can I use this flash in slave mode as well Thank you. Pete
Solution #1
posted on Sep 20, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Just drop your 60CT-4 F stop down by one and just shoot away.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Metz 60CT4 and VPS rated at 100ASA:
I don't want to Accept this solution
Solution #2
posted on Aug 08, 2005
Not Rated (0)
Jimmy NY
Rating: 0%, 0 votes
On 12 Jul 1997 19:47:28 GMT, dcjphtg @aol.com (DCJPhtgrfy) wrote:
I have noticed, when measuring flash output of my Metz 45 with a
Minolta Autometer IV, that the flash in its automatic mode overexposes
by about one stop. When I shoot, whenever I have the opportunity, I
measure the light with my Autometer and get perfect exposures. The
meter is spot on.
I guess Metz must think that it is better to compensate for
reciprocity failure and running the chance to overexpose, than it is
to leave it up to the photographer and run the chance to underexpose
and have dissatisfied customer. After all, overexposing is not as bad
as underexposing.
In this case you got bitten because you expose your film as ISO-100.
In a sense, this means double correction (by you and Metz). I bet that
exposure would be better if you set your flash to 160 or even 200.
Suggestion: Calibrate your Metz using a good flash meter and adjust
the film sensitivity on the flash until it gives the amount of
exposure you want it to give.
Michiel
Thank You!
Solution #3
Not Rated (0)
pandamama
Rating: 0%, 0 votes
I must not understand your general question regarding your mets and VPS.
I use VPS on weddings every week with the 60CT4 and have never had a this
neg. I rate it at 160 as it should be rated and my lab always gives me good
prints. Also, I often change film mid way in a wedding to ASA 100 for
example, and forget to let the Metz know what I did. The point being that
VPS has a good two stop lat.
I can not believe someone suggests that you problem would be solved if you
use a tripod, get real, you are doing weddings not photo class assignments.
Some questions that come to mind would be:
are you using the Auto setting on the Metz and a normal (80) lens? What
camera are you using?
Bob Johnston
Thank You!
Solution #4
Not Rated (0)
Cornish
Rating: 0%, 0 votes
I am using a Mamiya 1000s with an 80/1.9 lens.  I am not using a tripod.
I am using a stroboframe R4B bracket with my Metz 60CT4 and reflex
bounce card.
I set the Flash to ASA 100 and F-stop to F8.  My camera is set to F8.
Every camera is different.  I am going to vary the ASA on the flash
until I find a setting that works for my camera.
Kelan Griffin
Thank You!
Solution #5
Not Rated (0)
kioner
Rating: 0%, 0 votes
In article <33cb26bf.1479 @news.nlrtdfsc.origin.nl>,
Michiel.Fie @nl.origin-it.com.nospam (Michiel Fierst van
Better over than under-- how do you know they are overexposed?  My lab
has no trouble with this kind of overexposure, however you probably could
cut back a tad--  If they are printing them light-- you are using the
wrong lab.  Are you using a pro lab that normally does wedding work and
checks each negative?
I get too light prints all the time from many mini labs-- and I can see a
minilab doing wedding stuff-- averaging the faces with the dark
backgrounds-- Reprints are ok though.
Another tip-- you lose half the light with a tall ceiling-- another
reason people use "overexposure" a bit.
Great flash, if you don't like it , email me with a good asking price.  I
continue to use the CT2-- the flash is generally more important than the
camera in wedding work,  IMHO.
Also, if you are going to do this kind of thing-- wedding photography,
you might even consider the new 400 ISO Kodak Pro films-- they are great,
and nothing like depth of field.
Good luck.
John
-------------------==== Posted via Deja News ====-----------------------
      http://www.dejanews.com/     Search, Read, Post to Usenet
Thank You!
Solution #6
Not Rated (0)
man1
Rating: 0%, 0 votes
If you had densities around 35, you underexposed your VPS (by almost 3
stops). Your film speed setting, or aperture setting on your Metz was
probably not set correctly. Properly exposed VPS should have densities in
the 75 range.
Actually you need to shoot at a shutter speed of 1/60 or slower. It is a
good idea to shoot at a slower shutter speed (1/8 or so) on a tripod to
allow the ambient light to be visible on the film.
It's a good idea to rate VPS at about 100, in all situations. Be sure to
have your flash set at 100. Make sure your camera f-stop matches your
flash f-stop (in auto mode). A 60 series Metz would have a flash to
subject distance of about 24 feet at f8 (Guide # 197). Were your subjects
more than 24 feet away?
That's all I can think of for now.
DCJ
Thank You!
Can you Help with these Flashes problems?
Hello, Is there any problem using my Canon 1DmkII with a...
Flashes
I am running Windows XP-the dane usb flash drive was...
Flashes
help me find one for a vivitar zoom thyristor 3500 flash
Hi, Just purchased a Metz 60CT-4 and I'm needing a power...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
