Question about GPX D1816 DVD Player
GPX d2816 problem
New out of box GPX d2816 player, display on tv says "bad disc". Display on d2816 dvd player says" ddl SC. I put a dozen good video discs in unit and the same problem persists, "bad disc". Only thing the unit will do is turn off and on and open/close dvd door. TV display will say open/close and loading and then bad disc. Any help will be appreciated!!!
  • 1 more comment
  • Anonymous Mar 19, 2014
    wont open drawer or play on tv
    I have a GPX DVD that worked fine until I attempted to connect it to my new LG 55 inch TV. Trying to utilize the S-Video method and there seems to be no way to get this thing properly tuned. Have a picture, (black & white), no sound. Having trouble interpreting setup. Help! Need detailed instructions.
  • Anonymous Mar 30, 2014
    Brand new but can't open/close dvd slot/door.....any ideas?
Hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
I have the same problem, and I am really disappointed in the product. I am a mommy, who knows absolutely nothing about electronics. I hope this solution works, needless to say though I will be waiting for my husband to disassemble it- before I make the product even more screwed up! Thank you for your suggestion, and I will let you know if it works!
Posted on Aug 28, 2007
SOURCE:
Gpx users guide
GPX has multiple models. LBrown18062@hotmail.com
D108S GPX D108S: User Guide D1307 GPX D1307: User Guide • Specifications D1816 GPX D1816: Specifications • User Guide D1816SIL GPX D1816SIL: User Guide • Specifications D200B GPX D200B: User Guide D2816 GPX D2816: Specifications D2817 GPX D2817: User Guide • Specifications P PC308B GPX PC308B: User Guide • Specifications
Feb 04, 2012 | NEC Televison & Video
What's the code for the gpx dvd model 2816 to the rca universal remote
Hello
Remote code for GPX dvd with RCA RCR 311B remote is 3368. OK.
Jun 28, 2011 | GPX D2816 DVD Player
Why does it read bad disk? i've tried two disks, that work perfectly on another DVD player. But reads as Bad disk on the GPX D2816
its the disk laser sensor is to sensetive that why it canot reads with an ordinary disk or a pirated disk or a disk that has a small scratch.
Nov 07, 2009 | GPX D2816 DVD Player
Get display : NO DISC or BAD DISC
Probably the laser lens needs cleaning.
Purchase a laser lens cleaner disc at Radio Shack ($13). No chemicals are involved.
Read & follow the instructions. It cannot harm the player if not done right.
Sep 30, 2009 | GPX PDL705
GPX MODEL D2816
I heve worked with so many DVD players including playstation2 a while back. Almost all the time this problem is caused by a bad laser diode assembly. You can order one for your particular model, but they are not easy to replace, even for an electronic guy like me. A mechanical talent is a must.
Jun 29, 2009 | GPX PDL705
My gpx dvd player model d2816 keeps saying bad disc even with new disc
Either the lens is dirty or the optica are starting to fail. If you can gain acces to the optical assembly, try cleaning the lens carefully using a cotton swab and alcohol. If that fails to resolve the problem and you are able to read CDs but not DVDs, the optics are failing and need to be replaced.
Dan
Jan 05, 2009 | Televison & Video
No color on dvd player
A cable could cause this problem. I would try using a standard RCA patch cable and go from the composite video output of the DVD player to a composite video input of the TV. See if that produces color. If not, the DVD may be at fault. On the other hand, if you get normal color, the S-video cable could be bad.
Hope this helps.
Dec 14, 2008 | GPX D2816 DVD Player
GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Oct 12, 2008 | GPX PDL705
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
GPX D1816 DVD Player Logo
456 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Damen Wong
Damen Wong
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
