Question about Pioneer VSX-81TXV Receiver
Breaks in audio
Whenever i watch tv (using HDMI cable) the receiver seems to be searching for a different mode to play audio through. i've cycled through all of the different modes, but i still get a momentary break in audio about once a minute. during the break, the display on the receiver changes. i confirm that it is the receiver because i can just rewind whatever im watching using tivo and the audio that once was not there is listenable, of course until the receiver starts looking for a new playback mode. or atleast this is what i think it is doing. any help? thanks in advance
    Problem Solver:
  • 21 Answers
The receiver is not locking on the digital audio on the HDMI. Try a different cable or sat box if you use one. Use a digital audio cable instead of the HDMI to the reveiver. HDMI is full of issues.
Posted on Aug 27, 2007
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a Sa-ex900 amp hooked up to Television ,vcr and dvd player. When I turn the amp on and want to play the tuner , the television bleeds through. In fact TV plays through all buttons except VCR1
it seems to be ,you have a possible wrong connection..I
may I recommend you to check the connections in accordance with my model connection procedures given below and correct if something is misconnected..
I believe Your Television ,vcr and dvd player all connected to each other thru Technics Receiver itself (not directly connected to each other ) and whenever you want to listen/watch any of it ,you make a selection thru Receiver..
** in order to do this both DVD and VCR 's "2xRCA audio" and "1x RCA Video" cables for "IN" and "OUT" should go to Receiver separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected )
** Additionally your RECEIVER's prefably only "1xRCA Video Output " should go to TV to watch the video of both DVD and VCR (audio will come thru Receiver.)
Ok, now Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV .( every TV has different type of Audio out jacks )
** to "TV input "or "AUX input" or "Optic Cable input"
of your Receiver (whichever you want ,based on the necessary cables on your hand )
** than just switch to respective mode on
There you go..Tv sound are on the
Receiver .
continue f
Jul 07, 2011 | Technics SA-EX900 Receiver
No audio when watching HDTV and the home theatre receiver is set to cab/sat. HDMI cable is run from the receiver to the TV. Cable is run from the cable box to the receiver. Tried using "y" audio...
If your TV has HDMI in and digital optical out, run your HDMI cable via HDMI out on box to, HDMI in on TV then, run digital optical ouyt from TV to digital optical in on reciever. Your reciever has video pass through but, not the best option. Video components should run to TV then out to reciever. If you do not have digital optical out on TV, you may be able to use RCA.
Jun 24, 2011 | Insignia Audio Players & Recorders
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I cant figure out how to listen to the radio while i play video games through hdmi cables
In order for you to be able to have a different audio source from your video, i.e.; have "radio sound" instead of "video game sound", you have to connect your HDMI cables from the game console directly to the TV/Monitor.
The reason for this is that video and audio are carried simultaneously over a single connection on HDMI. If you make your HDMI connections through a receiver to a monitor, whenever you change your input to the radio you also lose your video game picture.
So to summarize;
Power off your receiver and game console.
Disconnect your game console HDMI cable from the receiver.
Reconnect the HDMI cable to the TV.
Turn on the TV, then the receiver, then your game console. Then change your receiver input to the radio.
Dec 12, 2010 | Yamaha RXV367 Receiver
Just connected our directv hd receiver to the tv via component cables, because we just bought a blue ray player and the only output for that is HDMI and since there is only 1 DVI input we had to change the...
You may be able the settings of your directTV box to stop frustrating you. If you help me identify the model you are using, I can research the proper menu choices you will need to choose to select the correct features. There are many different directTV set-top boxes available.
My own home theater setup did the same thing, and my solution was to use component cables from the PVR instead of HDMI cables. It is too bad your blu-ray doesn't allow for this configuration.
My work-around until I realized that using different interconnects fixed the problem, was to turn the TV off and then on again whenever switching from HD to non-HD sources. This fixed my problem, maybe it will fix yours.
I hope that helps.
Mar 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Pioneer VSX-81TXV Receiver Logo
90 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
