Question about Philips 43PP9202 43" Rear Projection Television
Help with Philips resistors
I too have a problem with my Philips 43PP930217 where I am having trouble with the red convergence lining up. I have pulled the board which shows two burnt out resistors. They have black, orange, gold, gold colors on them which indicates that it is 0.3 ohms +/-5% There are also two additional resistors which test okay, but there is a very slight brownish tint on them that are blue, brown, gold, gold which indicates they are 6.1 ohms +/-5%. I am going to replace both sets of the resistors and the ICs as a precaution. My problem is...where can I purchase the replacement resistors as I am having a difficult time locating some with these ratings. Also, I am unsure if they are 1/4, 1/2, 3/4 watt as well as the type of construction of these resistors. Can anyone assist me with this?
  • born-in-usa Aug 22, 2007
    I looked at www.globalelectronics.com and this site did not indicate they have any resistors. I also did not find any technical assistance. Any other solutions would be appreciated.
    Sergeant:
    Champion:
  • 375 Answers
Try www.globalelectronics.com
Posted on Aug 19, 2007
  • g w Aug 22, 2007
    try www.rich-tech electronic components
SOURCE:
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats wrong.....help
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Oct 27, 2010 | Philips 46PP9302 46" Rear Projection...
Red vert lines will not convergenge(sides) blue and green o.k.
your convergence output amps are done...
you have to do repair on the convergence output circuit, and inspect
the power supply for any damages.
Jan 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
SHOWING DOUBLES
Ur convergence ICS and all it resistors is dead,must know how to solders?Buy a convergence kit have all these parts,replaced Tries Tv repair world.com,TVrepairkits.com.
Jan 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
Getting lines to line up
Hi, if the green isn't straight to begin with you will need to go into the convergence sub menu and align it there code is 062597 status then follow the instructions to adjust the green first, then red , then blue multipoint and save it.
pressing menu to switch arrows to move/adjust status to back up , make sure to scroll down to save multipoint before exiting, power off when done.
If any color will not move or is more than 1 inch out of adjustment you may need to check the resistors to that convergence color .
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 23, 2009 | Philips 55PP9401 55" Rear Projection...
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
Convergence will not line up after replacing ic & resistors
Did you replace the resistors when you replaced the convgence chips? If one of them was bad you would still have the problem.
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 03, 2009 | Philips 51PW9303 51" Rear Projection...
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence trouble philips mod 51pp9303h/17
You can get a convergence kit with a photo instuction guide from www.TvRepairKits.com. The kit is for your exact model and includes the 6.8 ohm resistors.
Dec 07, 2008 | Philips 55PW9363 55" Rear Projection...
52 in philips help.
the large IC's on a big heat sink is where the convergence ic's will be
here is an example http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
the resistors will be on the lines of these IC's
need help identifying the resistor values?
Dec 03, 2008 | Televison & Video
55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Mar 28, 2008 | Philips 55PP9352 55" Projection Television
Philips 43PP9202 43" Rear Projection Television Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
