Home | Acer | AcerScan Prisa 620U Flatbed Scanner | I need a driver soft war...
Acer AcerScan Prisa 620U Flatbed Scanner
Problem for Acer AcerScan Prisa 620U Flatbed Scanner
I need a driver soft ware to work with windows
By elfondkya_ih on Mar 22, 2009
i need a driver soft ware to work with windows xpsp2 for acerscan prisa 310p
email: elfondkya_ihabmoh@yahoo.com
Solution #1
posted on Mar 22, 2009
Somewhat Helpful)
Stakanoff
Rank: Guru
Rating: 88%, 32 votes
Instructions for installing Acer brand parallel port scanners in Windows XP:
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web :
Mirascan_v3424p.exe
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on EPPSCANNER and where it says "Model" it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
Note: For additional screen shots of this procedure and installation procedures, please read the pdf file posted here:
scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but procedure is same for v3.424
Note: Adobe Acrobat Reader is required to view or print this file.
Note: not all XP systems will work with parallel port scanners. If the procedure doesn't work for you, then you must obtain a newer USB type scanner.
Was this helpful?
Yes
No
Solution #2
Not Rated)
ctau
Rank: Guru
Rating: 85%, 60 votes
driver available HERE
Was this helpful?
Yes
No
Popular Solutions for Acer AcerScan Prisa 620U
Questions and Unsolved Problems for Acer AcerScan Prisa 620U
Do you recommend Acer AcerScan Prisa 620U Flatbed Scanner?
Answer
Answer
no and it yuse a puge I frgot my surname
Answer
what do I need to do for acer 620u prisa to work with windows 7
Answer
I need the actual driver so that the Acer 620U PRISA SCANNER WILL WORK. I need it for windows vista
Answer
I am trying to find the driver for the Acer 620UT scanner for the Windows XP system. Can you help?
Answer
Hello I own a Acer Scan Prisa 620U and unfortunately we vacuumed & burnt out the power adapter... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer AcerScan Prisa 620U...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 1437
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
