Question about PreSonus Inspire 1394 Sound Card
No sound output
I have connected a inspire 1394 to my 933 Mhz ibook. I managed to get it to work once... but never since. Everything seems fine. It shows up in the sound in panel and the meter is responding, but I CANNOT MANAGE TO GET THE SOUND OUT THROUGH THE SPEAKERS - OR INTO ANY OTHER APPLICATION to capture it... OS is 10.4.10
Are you hooking up the headphone jack to the unit and not the ibook? When I hook inspire to my mac, the output comes from the unit, not the computer through the unit's headphone jack or the speaker output. Also make sure the volume is up and no channels are muted.
Posted on Nov 06, 2008
I'm having problem with sound when I use my Pioneer Elite VSX-32 receiver. Everything is fine if I directly connect to my TV with HDMI cables from my cable box or my roku box. However, if I use the same...
check the audio output settings of your components. THey may be set for dolby digital which your receiver can process but your TV can not. Try PCM stereo setting or "other".
Apr 29, 2014 | Pioneer Audio Players & Recorders
New hard drive on iBook g4
it is not an easy job to change a HD on an old iBook G4.
you need some experience in handling microelectronics.
step-by-step guide is available here:
https://www.ifixit.com/Guide/iBook+G4+14-Inch+933+MHz-1.33+GHz+Hard+Drive+Replacement/189
iBook G4 14 933 MHz 1 33 GHz Hard Drive Replacement 24100867-eger5opjetenbdaollq52u3v-5-0.jpg
Apr 12, 2014 | Computers & Internet
Evrything hookup there is no sound iget a good signal in the back of the sub so whats the problem
try connecting a speaker to the sub output terminals at low volume and see if it has loaded output, if it works , your subwoofers voice coil is open/blown
Jan 29, 2014 | Behringer EUROLIVE B1500D-PRO Active 15"...
My ibook won't charge. Everything works fine when it is plugged into wall socket Battery shows a black x in the battery indicator in menu bar. Computer has been idle for 60days as I was gone from home. I...
font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
To help with getting your battery to charge, try resetting the PMU
-PMU RESET-
The Power Manager (PMU) is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Now refer to this article from Apple.com Support
Resetting the PMU for Powerbook and iBooks
If this process does not help to allow your battery to charge normally, you more than likely have a battery which may be either dead or eventually will die in its charge capability.
What I would recommend if that is the case, would be to consider purchasing a new battery from Apple or via a third party reseller like online Apple authorized resellers like Amazon.com, MacMall.com or Fry's Electronics for example. You may also Google with keywords "purchase iBook battery " and shop for the best priced iBook battery.
Again, you would only consider the latter, if the former procedure listed above does not help.
I hope this helps.
Regards,
Mactechtrainer
Feb 04, 2011 | Apple iBook G4 Mac Notebook
Ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
Dec 19, 2009 | Apple iBook G3 Mac Notebook
Ibook g4 screen issue
That screen will most likely be compatible - I work on these for a living. The G3 laptop screens are usually not compatible with the G4 laptops, but all G4 laptop screens are compatible with eachother (provided they are the same size, of course.
Nov 10, 2009 | Computers & Internet
Grey screen on G3 ibook
Hi, Sorry you are having trouble,
Sounds to me like you're going to have to re-open that puppy and check all the connections, sometimes, when putting it back together, some cables are stretched and come un plugged...
Be careful, go slow...
Mar 29, 2009 | Apple iBook G3 Mac Notebook
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Mar 29, 2009 | Creative Labs Inspire T6100 Computer...
I have a pioneer 5.1 channel surround sound system and it powers up and everything seems to go fine but you go to turn it up and no sound comes out of the speakers already checked speaker wire connections...
Does the protection relay click 3 to 5 seconds after initial power on??? If not, your unit is staying in "protect" mode to save your speakers because the output transistors or output IC is shorted and sending 40 to 60 volts at your speakers. Not a good thing, but at least it saves your speakers.
Good Luck!
barneyluc
Oct 03, 2008 | Pioneer Audio Players & Recorders
Distorted sound output
If the motherboard supports IRQ assignment of PCI devices then YES.
Thank you for choosing FixYa!
Az. Wizard Division.
Sep 22, 2008 | Microsoft Windows Vista Home Premium with...
PreSonus Inspire 1394 Sound Card Logo
306 people viewed this question
Top PreSonus Computers & Internet Experts
Marcin
Greg Ulan
Tom Chichester
Are you a PreSonus Computer and Internet Expert? Answer questions, earn points and help others
