Question about Planar XP17W (White) Monitor
Monitor will not stay on.
I plug in the monitor and it will not stay on. I can not get the black back cover off very easily either. I have done things like this before so i am willing to do work on it myself. Thank you. I think it is the voltage controller for the cold cathodes.
  • hickfarm Aug 22, 2007
    Is there a way to fix these? If there is how do you drain the juice from them. If i get the monitor working I will for surely paypal you some cash.
    Problem Solver:
  • 9 Answers
I'd start with taking off the 4 screws and then you have to unclip the cover from the rear. Remove the metal shield to expose the boards. The most common problem is the 5 1000uf, 16v, capacitors. Replacing these(often they are leaking or bulging), should bring back your backlight.
Posted on Jun 25, 2009
    Scholar:
  • 76 Answers
It could likely be the flyback transformer, usually found in the right or left rear corner of the monitor. Be careful though, it packs enough stored power to kill ya. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
  • Anonymous Aug 22, 2007
    I must apologize!!
    I should have looked at the model # prior to giving my advice. This is not a CRT as I had assumed from your post.
    On this LCD (or any LCD for that matter), there is NO flyback transformer.
    I'm familiar with your problem, though and it could be a backlight failure, or an inverter circuit related failure.
    Your safest bet is to contact the folks at www.lcdrepar.net. I would go to their website, you will see they do serious LCD repair and diagnosis.
    If you want to email them, try their web based email page athttp://laptops.home.att.net/tuwytao.htm
    ZT3000
SOURCE:
Were does the little black hose go by the filter
The black hose is a drain. It drains the water out of the filter housing prior cleaning the filter. It has a plug in the end. Take out the plug and drain the water into a shallow pan. When done, the plugged hose just stays behind the cover.
Nov 15, 2015 | LG WM2016C
How do you connect 200897 battery, it is no longer working
I just bought a battery (readily available) for $16 and here is how I replaced it, but first, make sure UPS is disconnected from 120 Volt service. (Old battery number SW1233 with F connectors.)
Turn the UPS over and look for 1 tiny screw (even with the "in" telephone wire socket). Remove the screw (turn CCW). Push the button marked push, then slip a steak knife or sharp putty knife into the joint in front of the screw hole. Twist the tool enough to start the battery cover moving backward (to your left).
The battery is upside down. Lift it high enough to grab wires and pull them off the postst.
Verify battery you bought fits the housing. With UPS upside down, place battery on right side with lugs toward the power cable. Push red wire onto red post. Hold the battery upside over UPS. Push black wire onto black post.
Visually ensure the wires both run in their channels (otherwise the battery will not seat and the cover won't slide on.) Push battery into slot until it bottoms.
When the battery is bottomed properly, hold the cover about 2/3's over the battery housing, push it down, then push it toward the screw hole (to your right). If this operation, or the cover jams near the screw hole, check the battery. It must be absolutely bottomed in the slot. The cover won't go on easily even when everything is perfectly aligned.
After the cover is closed and the screw replaced, plug the UPS into a wall socket. The on/off button has a mind of its own, so ignore it. The green light may light and there is one beep. The backup yellow light may blink. The green light may stay solidly on. Pull the cord plug out of the wall. Now the UPS green light may go out and you will hear a ratcheting sound (the UPS is making AC from the 12 Volt battery current). Because you have no device plugged into a "battery-backup" plug, the UPS will shut off automatically in a few minutes.
The last test is to reconnect the plug to the wall service, then plug a monitor, a music system, or something similar into a Battery B/U connector. The green light should light. When the UPS is again unplugged, the yellow light (Backup) flashes and there is a repeating beep. Plug UPS back in. Only the green light will be on. That's it, all done.
I use Newpoint UPS to back up my telephone/modem. During a brownout, SPS powers those units almost 2 hours.
Note: This UPS is not suitable for powering or charging Laptops because the power output is too dirty.
R Hicks
Oct 22, 2013 | Newpoint (200897) (DHN200897) UPS System
Hi I have a Qosmio 300 and have only used it briefly a few times. Now when I start it up the screen stays black, it has power to it and lights up, but a black screen only. I checked the battery on the back...
After the computer boots up try connecting a monitor to your VGA port and see if the picture is shown on this monitor. if you see the picture it means that your laptop's display is damaged somehow. if there is no picture on the monitor it means there is a problem with your graphic card.
Tip: after plugging in the monitor press Fn + monitor key to switch the image onto this monitor
May 06, 2011 | Computers & Internet
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Screen goes Black about 1 or 2 seconds after powering up.
you have problem wit the lamp just plug in another once you removed the back cover and if the lamp stays on the it is 100%. you do not need original lamp. Any 15" lcd lamp that fits will do the job. HA HA well done
Ahmad
COMPBITS.COM.AU
Jul 06, 2009 | Computers & Internet
Acer AL1917W goes black
Are you sure that the monitor is the problem?
Did you check the video card?
Did you check your monitor in another computer?
May 22, 2008 | Acer AL1917W LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Wide vertical black and white bands
Hi, You may want to try and unplugging the power and video connectors of the Dell monitor. Check for anything out of the ordinary with the AC plug and the video connector. If none, plug them back in making sure that they are snug and fitted properly. If problem persist, see if it is possible to rotate the way the AC plug is connected to the mains (sometimes this works and can be done if you are not using 3-prong or the uneven 2-prong AC plug. Sometimes, this can also be done on the other end of the AC plug). Check your docking station (though unlikely but possibly). If still a no go and your laptop works ok, then your external monitor needs some looking at. This would involve circuit analysis and component level repair. Perhaps your best bet is to have a qualified professional take a look at it. Good luck and pls post back how things turn up or if you need further information. Kind regards.
Aug 20, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
Open Questions:
See all Planar XP17W (White) Monitor Questions
Planar XP17W (White) Monitor Logo
299 people viewed this question
Top Planar Computers & Internet Experts
Thomas F. Schneider
William Miller
William Miller
Joe Goldman
Joe Goldman
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
