Home | Philips | 30PF9946 30 in. HDTV-Ready Plasma Television | Black screen with sou...
Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Problem for Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Black screen with sound. Problem on every channel.
By berlee on Aug 18, 2007
The TV worked fine when we went to bed. In the morning it turned on with a black screen and had sound. We have checked all the cable connections (We have cable fine on our other TV). We have tried to pushing different buttons on our remote as suggested by the usuers manual (this did create our sound to go off since we could not see what results we were getting from pushing these buttons). We have been told that plasma TVs have a life of only so many viewing hours, and ours may have just died. Our TV is over two years old.
Same Problem
Feb 26, 2009
-   TV wen black, but has sound.  It is only 4 years old.-   shorethings
Feb 04, 2009
-   Exactly like everyone else has described. The thing is this TV has worked perfectly for over 3 years - at least in this regard. It's February here in Sydney Australia and the weather is hot and humid. I suspect the humidity may be causing the behaviour and by the sounds of things, a repair man may not be able to fix this.-   sdowse
Aug 05, 2008
-   Same issue, 3 years old with black screen with sound - weather is hot currently which may be contributing
will try to contact philips -   Guest
Apr 19, 2008
-   I have the same tv my screen works for about 5 mins then goes black, the sound is fine, if I switch the tv off for a few secs it will work again for 5 mins then again it will go black.
very annoying
-   bighairy
Feb 24, 2008
-   Black screen with sound-   Guest
Best Solution
posted on Feb 18, 2008
Helpful)
pdpmaster
Rank: Apprentice
Rating: 92%, 11 votes
If your tv have t296xw01 auo lcd panel the problem is a broken transformer at the inverter boar.
Was this helpful?
Yes
No
Solution #2
posted on May 16, 2009
Not Rated)
lchango1
Rank: Apprentice
Rating: 0%, 0 votes
Sound no picture or shut down Power led starts green then a short amber then turns RED . If your power supply can be confirmed to be go you have a bad Inverter board. Per the manufacture this part comes only with the panel . Not cost effective . But if you go to
lcdparts.net you will locate an inverter for $ 169.99 . I had the same problem and the inverter repaired the set . Note there are similar error codes but from what I can see from all of your complaint I do be leave that your Inverter is bad . Good luk
Chongo
Was this helpful?
Yes
No
Solution #3
posted on Nov 08, 2007
Not Rated)
Terryfic
Rank: Guru  Philips Expert
Rating: 87%, 1703 votes
Has not died = needs repair by qualified tech......
Did you try hard reset by unplugging ac cord for a while?
Next, voltages need to be checked inside TV.........
Let me know where this repair is going........T.
Was this helpful?
Yes
No
Popular Solutions for Philips 30PF9946 30 in.
Questions and Unsolved Problems for Philips 30PF9946 30 in.
Do you recommend Philips 30PF9946 30 in. HDTV-Ready Plasma Television?
Answer
Answer
The white on my Philips 51pp9303h-17 is too bright. The picture is good and I have the brightness... (More)
Answer
Verizon remote sylvania tv tried all codes plus total search,no luck.Do I key on TV or STB?
Answer
Can you fix a Altell Blackberry Curve
Answer
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the... (More)
Answer
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent... (More)
7 Other Users Have The Same Problem - Continued
Comment by harby72, posted on Feb 18, 2008
One day the picture and sound are fine, then suddenly the screen goes black but I can still hear sound. TV is 3 years old.
Comment by cbyrne, posted on Nov 17, 2007
I've had the same problem for the last 3 years with this TV. It began the day I bought it. I thought I had hooked up the cables incorrectly at first, but that is not the case.
It seems to be a cold weather or low pressure weather issue. the worst months are October to April. All during the summer months in New York City is operates perfectly.
The problem for repair is that it is so unpredictable that if you called out a repair person, there is no guarantee you can recreate the issue which is so infuriating! Any clues to what might cause this?
CB NYC area.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 30PF9946 30 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
