Question about Frigidaire FRS23R4A Side by Side Refrigerator
Freezer temp freezer will only get to 15 deg. and it should be 0 deg. will a recharge fix the problem and if so since it is r134 can I do it myself? Thanks
  • dickhip Aug 23, 2007
    no other problems. controls have been adjusted
    in all ranges down to the coldest.
  • 291 Answers
Do you have a problem with the fridge other that. Have u tried adjusting you controls .. freezer and refrig. ? That should be ok unless you having problems with something else ... like say ice maker
Posted on Aug 21, 2007
SOURCE:
What is the normal fluctuation range of a top freezer in a freeze-refrig combo? That is if I set the temperature of the freezer a 0 F, at what temperature should the freezer come on to keep the air i
Hello Richard;
My name is Peter. I am a retired field service refrigeration technician.
The normal range for a freezer is -2 to +2 Deg. F.
The normal range for the fresh food section is 35 to 40 Deg. F.
If you set your freezer at 0 Deg. F. it will stay at 0 Deg. F.
When the freezer temperature drops below 0, your compressor will kick in to bring the freezer back to 0 Deg. F.
Dec 15, 2014 | Frigidaire Refrigerators
How lpw of a temp. Can this freezer reach..and and if only 0 degree could the thermostat temp control be changed out so it could reach les than 0 temperatures like negative 20 or so?
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
Sep 18, 2011 | Beverage-Air 44.9 cu. ft. / 1271 liter...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Need to know how to change the temp on the frige part also whats the correct temp it should be at
    need to kow brand and model # of frig to help / tempts for frig 38 deg and freezer 15 deg or lower to 5 deg .. mm
    Apr 19, 2010 | Refrigerators
    Ice maker not making ice
    ck the tempt in freezer side should be 15 deg or lower to 0 deg . . adjust tempt control first / clean coils in back /and make sure both fans are going .. mm
    Dec 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
    Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
    Mar 17, 2017 | GE Refrigerators
    Temp problem. freezer temp 0 deg. fresh food 46 deg.
    An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
    Mar 12, 2009 | Refrigerators
    GE PFS22MISBBB freezer not cold enough. Temp won't reset.
    replace the fan as quickly as possible it may be shorting and causing damage to your control board,
    Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
    Frigidaire FRS23R4A Side by Side Refrigerator Logo
    Top Frigidaire Refrigerators Experts
    John Tripp
    John Tripp
    Steve Allison
    Steve Allison
    Thomas F. Schneider
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
