Question about Canon i860 InkJet Photo Printer
My magenta will not print well
I have run all the ink head cleaning and deep cleaning procedures- several times each, and my magenta still refuses to print well. I can sometimes get a pink faded line when I do a test page, but more often than not, it is white where it should be red. I printed a large picture of an apple or something- all red, to try and get the clog or whatever out- still no go. I switched out an almost full magenta cartridge with a brand new one, the problem still persists. Please help
  • aharuvi Feb 06, 2008
    I did the magenta test problem and my magenta is broken. The black works perfect. I even installed a new magenta cartridge. What do I do now?
  • 76 Answers
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
New ink tanks for I960 - pics have a green cast...head check indicates magenta and photo magenta not printing. Have already tried cleaning and deep cleaning????
This printer model has a print head seperate from the carts. Over time, the print head can become clogged. Try removing the print head assembly from the printer and dipping just the printhead (the silver thing on the bottom) into a shallow dish of just boiled water several times. Dry off, reinstall print head and carts and try again. My need to do a few times. This will get rid of any congealed ink on the print head. Otherwise, new printer, as the replacement print head is more expensive than a new printer. Canon kind of made these disposable. Can also try to inject water through the cartridge port when the printhead is out of the printer ( the hole where the cartridge goes into) with hot water as well...
Aug 08, 2009 | Canon I960 InkJet Photo Printer
Nozzle Still Clogged After Following Maintenance Procedures
just wipe the nozzles or the printhead .on a wet cloth...using DI(deionize water) to remove the clogs that cover nozzles...and then deep clean the printhead using the printer panel features...
good luck..
May 26, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Magenta ink ran out,continued to use printer,replaced ink tank twice,have done cleaning & deep cleaning several times no magenta coming through,all other colours ok. what to do next?? anybody have...
Think you may have killed your print head, but try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 01, 2008 | Canon Office Equipment & Supplies
Printer is printing everything in pink
more details please:
model number
if it's an inkjet, run any maintenance procedures like cleaning heads, take out each cartridge, take paper towel wet with warm water and touch nozzles gently to remove any dried ink.
Apr 07, 2008 | Canon Pixma MP950 All-In-One InkJet...
Canon i860 InkJet Photo Printer Logo
632 people viewed this question
old marine
old marine
