Question about KitchenAid KESK901SSS Electric Kitchen Range
Oven is blowing out hot air
My brand new oven is blowing hot air our. It's not just the vent above the oven door. The hot air is coming out from underneath the oven door and ablove the pan drawer. Not too pleasant during this hot summer. Help!
  • mfuqua Aug 24, 2008
    Same problem, I think ours only blows out the vent but it does not do much for our kitchen in FLA in the summer.
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Kenmore oven blows hot air out at top
The hot air is supposed to come out so you can heat other things. If the oven is loosing heat, try to see if vent has flap, or test the temp sensor
Posted on Sep 10, 2009
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Maytag oven blowing hot air from bottom vent heating house
Wanted to know if you found the answer. I have the same problem.
Aug 31, 2012 | Maytag Ovens
Hi newish oven,seems when all the ovens are off the fan is blowing cold air, any ideas?
cold air from the fan forced element area in the oven? or from the air vent just above the door? if its from the air vent then this is normal if your oven senses the outside cabinet is getting to hot it will bring on the fan and if its still to hot after u turn it off the fan will continue as its circuit doesnt run through the control knobbs meaning it wont turn off with the oven its controlled via a overload thermostat so the fan will remain on til it gets within its acceptable temp range and the thermostat will cut power to the fan, if it remains on for hours and hours or even days you will be looking at a new thermostat (cheap as dirt like only a few bucks) or worst case a controller
Apr 02, 2011 | Stoves 600SiDOm Gas Kitchen Range
Do i need to ventilate my wall oven
No, all wall ovens have a built in cavity extractor fan. When the oven is turned on this fan operates and blows air from the oven cavity through a vent at the front of the oven, normally just above the door. This keeps the outer oven and cabinet cooled sufficiently.
Feb 27, 2011 | KitchenAid KEBS177 Electric Single Oven
When the oven is on cold air constanly comes out the vents over oven door. Never did that with ild oven. thanks
This is the oven cavity extractor fan. It removes all the hot air from the oven cavity and blows it out the front. When the oven is hot and you turn it off the fan will continue to work until the oven cavity cools down.
Feb 12, 2011 | GE Ovens
MY PILOT KEEPS BLOWING OUT BUT THERMOCOUPLE IS BRAND NEW I AM GETTING FRUSTRATED BECAUSE IT GOES OUT AND THEN I LIGHT IT AGAIN AND IT WORKS WHY DOES THIS KEEP HAPPENING.
There can be a number of things causing that...
Is the oven vented? If so then is there a good cap on the pipe?? is the vent pipe high enough above the roof line?
Is there a draft diverter at the back of the oven where the pipe hooks on? A direct connection can cause this...
Is there a vent hood in the room that the oven is in??? Is there enough makeup air, or is the vent blower pulling air back down the stack?
Is the main burners "pulling" the pilot flame away from the thermocouple?
Is the "hood" on the pilot flame adjusted properly to keep the flame on the thermocouple?
Is the thermocouple positioned in the flame properly?
Is the thermocouple correctly tighten into the gas valve?
These questions are what I would be looking for if I was troubleshooting that appliance...
heatman101
Dec 09, 2010 | Bakers Pride Y-600 Gas Single Oven
When baking lots of hot air blowing from top vent
It is a good thing that the heat blows out. Electric oven didnt have anywhere to vent so the cpu boards got hot and burned up. So to correct this problem there is a little fan that blow out the heat so the cpu board doesnt over heat. thats all.. no worries mate
Mar 25, 2010 | KitchenAid Architect Series KEMC308KSS...
Sep 10, 2009 | KitchenAid KESK901SSS Electric Kitchen...
Too hot
first thing is to check if it is front vented or rear vented, if it is front vented you will find warm air blowing out above the door. if not it is rear vented and must have a flu installed behind unit.
Feb 18, 2008 | New World E70DOa Electric Double Oven
KitchenAid KESK901SSS Electric Kitchen Range Logo
453 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
