Question about E-Machines eMachines Desktop PC
Print screen key on computer.
How do i get my print screen key to work on my emachine computer?
    Problem Solver:
  • 6 Answers
On a windows computer by hitting print screen you are only copying an image of your computer screen to your clipboard you then have to paste it into an imaging program and save it. For example ... hit the print screen button on your keyboard -> go to start -> programs -> accessories -> paint -> then click the edit menu and click paste you should then see the screen shot of you computer in the paint window you then can go to file -> save and save the image somewhere on your computer.
Posted on Mar 22, 2009
  • 54 Answers
Ok, just press the prtsc key then click on start-run-type mspaint then press enter & click on edit then paste.
Thanks for contacting Fixya.
SOURCE:
Emachine em250
You'll need to have the power cord attached. This will not work if you are running on battery. While booting up, depending on your type of computer, you'll need to press a special function key repeatedly (for my computer it was F8) to bring up the recovery screen for your computer. Then follow the instructions on the screen. I also recommend you check out the website for your particular computer for more information.
Jan 12, 2014 | eMachines eM250-1915 Netbook
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
How do i take a screenshot on a E627
There would be a print-screen key on the keyboard, press it for the screen of which you want the print-shot, and then paste it either on paint or ms word doc.
Apr 25, 2013 | eMachines Computers & Internet
Keyboard wont print screen
Try unplugging your keyboard, restarting your computer and then plugging the keyboard back in.
If there is no change, try updating the keyboard driver by going to "Start" and searching for "Device Manager". Find your keyboard on the list of devices under the "Keyboards" section.
Right click on it and click "Properties" then "Driver" and then "Update Driver"
Apr 04, 2013 | eMachines EL1333G-01w
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
EMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
Emachines t1116
Usually e-machine and other pc's have a factory restore setting set up in case of an error. You can; according to emachine tap the "Alt" and "F10" keys at the same time when the eMachines logo appears. Press "Enter" and follow the directions on the screen to recover the operating system back to factory condition. I hope that helps, if those keys don't work try F11 at the emachine logo. Good luck.
Nov 17, 2011 | E-Machines eMachines Desktop PC
How do I enlarge the print on the pages so it is easier to read?
If you want to know how to enlarge the print while visting web pages, there's a little trick you can use with your mouse if it has a scroll wheel.
While pointing the mouse at an area on the screen, hold down one of the keys labeled Ctrl on your keyboard (there should be two). Then roll the wheel on the mouse forward to enlarge the screen and backward to reduce the size.
This will also work in some applications, but you'd have to try it to be sure.
Mar 07, 2010 | E-Machines eMachines Monitor E15T4
Is there a system recovery disk for the emachine ET1161-07 desktop pc?
If you bought the computer new and did not receive a recovery disc with it then the recovery software can be reinstalled from a hidden drive built into the computer.
The steps for re-installation:
  • Restart the computer
  • When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
  • When prompted with a boot screen, hit the Enter key.
  • After the system recovery program has loaded, follow the prompts to reinstall the operating system.
If you bought the computer used try the above method. If that fails then it came with a recovery disc but you didn't get it with the computer. The only thing you can do is contact eMachines support for help or purchase a new copy of Windows and reinstall it with that.
I hope this helps. If not and you need any help with reinstalling a new version of windows please let me know.
Oct 22, 2009 | eMachines ET1161-07 Desktop PC
Stuck on emachine screen
Hi there
Hit F2 on boot up and get into the bios settings, if it lets you in choose default bios settings, save and reboot, see what happens
Good luck
Jan 08, 2009 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
1,004 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
