Question about Pioneer VSX-D711 Receiver
Change channels My wife took the remote and pushed a number of the buttons. Ever since then I cannot change the station. I have tried both the up and down and pre sets. It is stuck on one channel. PLease help if anybody can.
There should be a button that says "input" if so try that a couple of times. Take the batteries out of the remote and unplug the TV for 30 seconds Hope it helps.
Posted on Aug 19, 2007
SOURCE:
How to set radio stations?
Hello Linda Price...
Varies by make & model...
year would've also helped.
The most common way is to DIAL-IN the STATION
you want to PRE-SET you want ...
THEN simply push and hold
(just a good 4 second count ought be adequate)
Some radios give a beep to confirm...
There is (of course) another version ...
My wife's little German radio has a "memory" button...
"Position" over the station you want...
Press the MEMORY BUTTON... THEN the station
PRESET... & release.
BINGO...
The actual way to find out is to read the owners manual.
For USA models MANY FREE manuals can be down loaded
(below)
ManualsLib Makes it easy to find manuals online
hope this helps
Carnac the Magnificent
May 24, 2017 | Cars & Trucks
Chrysler 300 radio cannot pre-set tuned stations
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
Feb 20, 2013 | Chrysler Cars & Trucks
Pulled radio to get serial # and now I can't get the radio to go into code input mode. it just says "safe" and the icon for pause is on
If you've entered a bad code a couple times, you need to wait an hour while the radio and ignition are on. Then, turn on the radio, SAFE should be displayed. Then Press the FM1 button and hold it down, then while holding down the FM1 button, press and hold the AM buttons so that both buttons are held down simultaneously. Release the buttons. Now enter the correct code using the radio pre-set station buttons (one through 4). Button 1 changes the first digit in the code "1"000, Button "two" changes the second digit in the code 1"0" "three" 00, button changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the FM1 and AM button simultaneously as before until SAFE is displayed, then release the 2 buttons, and now the radio should now work.
Jan 21, 2013 | 1993 Audi 100
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
I'm trying to change my radio station. The instructions say to push the snooze up or down arrows. But all that does is change it to one preset station to another. I don't want the preset stations.
For me with the M302 moondance system, the remote Tune + and Tune - buttons change the FM station (when the unit is set to FM as the source). Press and hold for 3 second to scan to the next clear station. The Track Forward and Track Backward switch between the presets.
If you are using the buttons on the unit, you can only search through the preset stations with the Snooze Up and Snooze Down. If you do not have the remote, you need to replace it. I believe this is the correct one: http://www.alteclansing.com/ae/restofworld/accessories-parts/wireless-remote-m302-a13547/invt/a13547/ .
I hope this helps.
(btw the manual for the M302 is available here: http://www.alteclansing.com/ae/restofworld/ipod-iphone-speakers/moondance-home-m302/invt/m302/ . Click on the icon with the down arrow.)
Nov 11, 2010 | Altec Lansing M302 moondance HOME Alarm...
I need to set the clock on a CD/cassette radio in a 1999 Ford E 450...also how do I set preset stations too?
Station Pre Set:
You can save 4 pre sets on this radio (1-4) tune the radio to the station you want to save then PUSH and HOLD one of the pre set butons until the sound returns, the station is saved to that pre set. Repeat for the 3 presets.
Clock:
Hour: Push and hold the CLK button and at the same time push the SEEK button to adjust. < decrease hours > increase hours.
Minute: Push and hold the CLK button and at the same time push the TUNE button the adjust. < decrease minutes > increase minutes.
Jul 14, 2010 | 1999 Ford Super Duty F 450
How do I reset the radio stations to be programmed into the radio? I did not receive an owners manual when I purchased my 2000 Mazda MPV Minivan
TRY THIS. GO TO THE STATION YOU WANT. PUSH AND HOLD THE SELECTED PRE-SET BUTTON YOU WOULD LIKE TO PROGRAM. PUSH AND HOLD TILL THE DISPLAY OF THE STATION BLINKS OR THE RADIO BEEPS. IT WILL BE FOR A FEW SECONDS. TO CHECK, TO THE STATION THEN PRESS THE PRE-SET BUTTON TO SEE IF IT STORED YOUR STATION. LET ME KNOW.
Feb 17, 2010 | 2000 Mazda MPV
Radio code
If you don't have the radios security code, you can try entering 1111 as some replacement radios were coded with this security code. Your local Audi Dealer may be able to provide the correct security code for your vehicle, if you provide them with your vehicles Identification Number (VIN). This VIN is typically located on the drivers door pillar.
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
To enter the code on the Wiesbaden Radio: Turn on the radio, SAFE should be displayed.
Push and hold the AM/FM button, then while holding the AM button down, push and hold down the SCAN button. Release the AM/FM and SCAN buttons, and the display should show 1000. Now enter the correct code using the radio pre-set station buttons (1-4). Button 1 changes the first digit in the code "1"000, Button 2 changes the second digit in the code 1"0"00, button 3 changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
After entering the correct security code, push and hold down the AM/FM button, then while holding down the AM/FM button, push and hold down the SCAN button. The display will then show SAFE, release the two buttons, and now the radio should play correctly.
Sep 19, 2008 | 2001 Audi S4
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Phil20124
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
Pioneer VSX-D711 Receiver Logo
193 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
