Question about Whirlpool MH1150XMQ Microwave Oven
One touch My one touch buttons will not work at all and my display has an up and down hash mark. I unplugged and thought maybe there was a reset....nothing. It works, just cant use my popcorn or baked potato buttons.
  • Anonymous Mar 29, 2014
    THE TOUCHSCREEN IS NOT WORKING ON CERTAIN NUMBERS AND THE CANCEL OFF BUTTON - i WANTED TO POWER IT DOWN TO SEE IF THAT RESET THE BUTTONS.
  • Whirlpool Master
  • 9,173 Answers
This is an odd failure for this model, assung yours is a model MH1150XMQ, since it does not have a humidity sensor. So it sounds like you may have a bad kepad or controller, or maybe moisture or grease got onto the board, casuing it to fail. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Below is our information on keypads, too: A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. DISCONNECTING AND CONNECTING THE MEMBRANE SWITCH (KEYPAD) 1. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the control circuit board. 3. There are two tiny tabs (one on each side) on the hood of the connector that you can gently pull up on to unlock the connector. Use equal and gentle fingertip force when pulling up. 4. The old keypad strip will lift out. 5. Put the new keypad strip in, making sure both sides are down fully. (If you are not installing a new keypad, clean yours with a pencil eraser or a soft cloth and alcohol.) 6. While holding the strip down, push the connector hood back down to lock it. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
SOURCE:
My microwave has a new icon in top left corner and no buttons will work now. Time still displayed but nothing works. I try pushing any button but nothing. What's going on?
I know this sounds basic but have you tried to unplug it and plug it back in...?maybe also look for a reset button somewhere in the back ?
Jan 29, 2015 | In Microwave Ovens
Cannot unlock the display panel
Elise,
So I'm understanding that the lock icon stays on no matter what you have tried. I would try pressing and holding the START/STOP button for 5-10 seconds to see if it changes. I don't know how long you've been leaving it unplugged for when you do unplug it, but i would suggest at least 3-5 minutes. If these don't work what I would do is either contact the manufacturer or maybe even a local authorized technician. This way they would be able to assist and possibly have some more suggestions or be able to find and solve the issue for you.
-Best regards-
Jan 16, 2014 | Frigidaire FFMV164LS 1.6 Cu Ft 1,000 Watt...
Lock function reset for model JMV8208BAS
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
The owner's manual is online here and it covers the child lock:
To set the child lock.
Touch and hold
ENTER/START
pad more than 3
seconds. CHILD
LOCK ON will
appear in the display
window with two
beeps.
To cancel the child
lock.
Touch and hold
ENTER/START
pad more than 3
seconds. LOCKED
will disappear and
you hear two beeps.
Aug 18, 2010 | Jenn-Air JMV8208BAS Microwave Oven
The display screen lights up, but nothing happens when the buttons are pressed
If it's still bad, you probably have a bad keypad. If so, get more info here.
Aug 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a kitchen aid over and the control are currently under control lock..i have tried holding down the # 3 button to unlock it but nothing seems to work..what can I do to unlock my oven
You can download Kitchenaid / Whirlpool owner's manuals and installation instructions here.
If the code "F2" comes up on the display, your membrane keypad is bad.
If so, feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Jun 16, 2010 | Microwave Ovens
Timer/clock touch button doesn't work anymore - worked this morning. can that be repaired? I unplugged the unit to reset now there is no clock display anymore and I can't set the clock either
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
[email protected]
May 25, 2010 | Sharp R-316FS Microwave Oven
Display light has the number 7. The oven has no
If that doesn't work, leave it unplugged for maybe an hour.
If you still have trouble, you may have a failed keypad or controller.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
[email protected]
Dec 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Screen/ keypad seem to be locked
Sounds like the child lock has come on.
This addressed in your owner's manual. but if for some reason you don't have your owner's manual, you can download Maytag owner's manuals and installation instructions here.
Just enter your full model number.
If it's not the child lock,
I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work,leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Dec 23, 2008 | Maytag MMV1153A Microwave Oven
GE Microwave DEMO MODE
The owner's manual (which can be downloaded here) doesn't show any demo mode, but it may exist.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Oct 06, 2008 | GE JE1590 Convection / Microwave Oven
Microwave came on by itself
Yes this is usually caused by the touch assy, but $278 !!!!! Thats kinda steep considering the panel assy is only around 30-60 bucks!!! It will need the touch assy and even possibly the control board, because sometimes the logic IC gets fried and causes "ghost issues" as well.
Sep 17, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool MH1150XMQ Microwave Oven Logo
93 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
