Question about Euro-Pro Shark SC-505 Handheld Steam Vacuum
How much water do I add?
I lost the fill cup that came with the unit. The instuctions I downloaded said to add 800 cc of tap water. Can someone tell me the amount in fluid ounces? Thanks.
    President:
  • 1,114 Answers
800 cc = 27.051218 US fluid ounces You can use Google to do most conversions online. To get the above I just put "800cc in fluid ounces" in the Google search bar & hit enter - great!! Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 18, 2007
SOURCE:
My Bissell wont spray water
Then check out the plumbing and mechanism responsible for the spraying of the water. Trace it out.
Aug 27, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
The cleaning solution does not dispense
Hello, this is Ava with Think Crucial.
There are a number of reasons why your unit doesn't spray water. It could be that the !) water tank is empty which you can fill heavy duty bladder with hot tap water. 2) If Formula tank is empty, you can fill it with Bissell 2x formula for cleaning. 3) If tank may not be seated properly, turn the power off, remove and reseat the tank. 4) If pump may have lost prime, try to turn off and then turn on the unit, wait for one minute and depress trigger. If still nothing happens, I suggest you contact Bissell 1-800-237-7691 for further assistance.
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website
http://www.thinkcrucial.com/search?type=product&q=bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Aug 06, 2016 | Bissell 1698 PowerSteamer ProHeat Upright...
Water won't spray when I squeeze the trigger. How do I get it to spray the solution?
Ava B.
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
I need to know how much water to put in it.
press the helpful button
Fill the provided measurement cup to the maximum fill line with water. In areas with a high mineral concentration in the tap water, we recommend using distilled or demineralized water to prolong the life of the steam cleaner. Using the funnel, pour the contents of the cup into the reservoir.
Top Innovations, Inc.
400 NW Platte Valley Drive
Riverside, Missouri 64150
www.mitcoproducts.com
1-800-711-6617
http://steamerstore.com/steamfast/manuals/SF-250_Manual.doc
Jan 28, 2016 | Steam Fast SF-250 Mouse Vacuum
No liquid through accessory hose
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website http://www.thinkcrucial.com/search?type=product&q=bissell
Ava B.
Nov 08, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How much water do I add to the steam buggy
I measured it for you, from my cup.
It's 18 Fl ozs or 500 ml (1/2 litre)
Anybody know where I can buy a spare nozzle.
Jul 01, 2009 | Tristar SB Steam Buggy Vacuum
Euro-Pro Shark SC-505 Handheld Steam Vacuum Logo
142 people viewed this question
Top Euro-Pro Vacuums Experts
Sheldon Dedek
Mark Bowens
Mark Bowens
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
