Question about Nikon N70 35mm SLR Camera
Bought used N70 "err" Help
I bought a used N70 and just purchased new batteries and now when we turned it on I have an "err' and everything flashes. Even when the lens is off I have the same error. Is there some way to reset to original settings or is that not the issue, I also looked when the lens was off and the mirror looked as it was locked in a inverted position.??? What can I do?
  • asa301 Jan 04, 2009
    I have the same exact problem. I just received my camera from keh.com- It was used but supposedly in "excellent" condition. I'm using 400 TH film. Could this be the problem?? However,similar to the previous post's problem,the  "err" message is present even when the film isn't.
I have the same problem.... I have a Nikon 80-200 AF Nikkor 1:4.5-5.6D. I installed my Nikon AF Nikkor 28-80mm 1:3.3-5.6 G and still have the problem...
The 28 and 80-200 work well on my Nikon F65.
chuck
Posted on Mar 25, 2008
SOURCE:
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
NIKON N70
The Err usually appears because the camera is in one of the auto shooting modes and the lens is either not mounted or is mounted, but is not set to the smallest aperture setting (ie 22)
Jan 04, 2009 | Nikon N70 35mm SLR Camera
'Err' & 'E"
Is the film loaded correctly? Have you tried reloading it? Also is it flashing DX too? That would mean the film speed is not DX coded so you need to set the film speed manually.
Sep 23, 2008 | Nikon N80 35mm SLR Camera
Nokia n70
Don't try anything. Take phone to someone who has toolbox to flash it. Just write latest firmware version in it it will work 100%
Aug 17, 2008 | Nokia N70 Cellular Phone
My N70 Won't Turn On At All
petrosp your n70 needs to be flashed with new firmware. In the worst case some hardware got damaged
Aug 11, 2008 | Nokia N70 Cellular Phone
My n70 is warm to touch
try to buy a new battery for that and keep your phone to lock so that it wont open their lights everytime your not using it.
another tip: drain your battery before charging it and make a full charge after you use it. hope that helps
CHARCOIS
Jul 27, 2008 | Nokia N70 Cellular Phone
Flashing Err and E/Error Problem
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
Dec 17, 2007 | Nikon N55 35mm SLR Camera
Help n70 not working
Well the only solution for you is go to the nearest nokia true care or any Nokia priority and ask them to flash your phone.
If ur phone's under warranty then it'll be done for free or they'll charge you 200 rs/-
Dec 06, 2007 | Nokia N70 Cellular Phone
Film won't adanvce
Needs new batteries, or the film isn't loaded properly. Check the battery area for rust too and clean the contacts gently with a pencil eraser.
Sep 12, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Nikon N70 35mm SLR Camera Logo
353 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
