Question about Acer Veriton 6800 PC Desktop
New pc won't boot
After putting together my system (asus m2v 64 2x 4200+ 65 watt x1950 pro 256mb 1gb ddr2 corsair value a shuffle atx400 400 watt psu) I've plugged in the power cord I could hear continuous beep (without powering on) after pressing power on button nothing happened. The mobo led doeasn't even goes on.
  • 2 more comments
  • Foxhound009 Aug 19, 2007
    It's actually one single continuous silent high sound and I don't even press the power on button, but thanks for help. So the motherboard could be defect? Could explain the led(not on).
    Thanks for help. I'll try this one, I just need to wait till shops go open. btw does the post test starts when I plug in the power cord or when I press the power button? sry I'm new to these things :)
    but my beep (sound) start even if I don't press the power on button, it starts when I plug the power cord in :S , Ive checked the qualify vendor memory list.. my memory module isn't on it. Thanks again :)
  • Anonymous Mar 15, 2014
    My tower continually beeps. I have put power supply into back turn on at front of PC all fans turn on then a continues beep noise like an alarm with no further action. I have repeated the same process with no luck. What would this be?
    Scholar:
  • 85 Answers
Continuous Beeping: Memory or video problem This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem. hope this helps
Posted on Aug 19, 2007
  • atlas  repair
    atlas repair Aug 19, 2007
    hi again,
    1 continuous beep is definately memory, check your motherboard's manual for compatible memory
    supported by your motherboard
    your motherboard actually takes DDR2 800 try using kingston memory which comes with lifetime warranty sometimes cheap memory modules are not supported by some motherboards
    good luck again
  • atlas  repair
    post starts after you press the start button
SOURCE:
Hi i just bought an asus m4a88td-m i instaled it with a amd phenom II x4, 500 watts corsair power supply, ati radeon hd 5700 1gb ddr 5 , 6gb ram ddr3 1033mhz and im unable to boot my windows 7 64bits , it...
With all that power, you need a better PSU, the CPU alone draws out 125 watts, the video card can get upwards of 50, RAM takes it down another 25, and that's half of it right there. I would suggest AT MINIMUM a 700 watt PSU. Newegg has em for you (you sound like you can find what you're looking for after all those specs you've given).
I hope this helps!
May 05, 2011 | ASUS Computers & Internet
Do I need to buy 2 DDR2 Ram for my ASUS P5VDC-MX Motherboard?
with rams, if the memory it has is higher than that of your cpu, the pc will not boot up or if it is too low compared to your cpu again.
thus, you say it has got two slots right, remove both of the 512's and insert the 1gig only, run your computer, i am sure it will boot up nicely. switch it off. put one 512, if it does not boot then you should know that your ram has an excess of memory that your cpu could not apprehend to.
post a coment if this does not work.
thanks,
wonder
Sep 18, 2009 | ASUS P5VDC-MX Motherboard
Asus p5 vdc-x motherboard not recognizing ddr2
Ok i am just guessing here
maybe your motherboard does not support
ddr2 rams and hence it wont boot up as it does not detect any ram in the slots......
try to boot with one old and one new ram (ddr and ddr2) and post the result
are you sure whether the ddr2 ram is supported?
Jun 30, 2009 | ASUS P5VDC-X Motherboard
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
Ram
Your motherboard can take DDR or DDR2 RAM modules.
Crucial says: "Each memory slot can hold DDR PC2700,DDR PC3200,DDR2 PC2-5300 with a maximum of 1GB per slot." No sense getting 4GB since the max is 2GB.
You can get higher speed RAM (PC2-6400) because it is backward compatible.
I would go with the 2 X 1GB Corsair from the ones listed.
Or consider the options on Crucial's site. See this page:
http://www.crucial.com/store/listparts.aspx?model=P5VDC-MX
Two 1GB modules of DDR2 PC2-5300 run about $34 US.
(PS. Your 450W power supply will handle about anything.)
Jun 03, 2009 | ASUS P5VDC-MX Motherboard
Monitor goes into 'Power Saver Mode' on boot up!
You need to upgrade your motherboard BIOS to the latest version (V.5a) to support your DUAL CORE 2.5Ghz processor... that's the problem.
Visit:
http://tw.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2779
http://tw.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=2779
Jan 07, 2009 | Corsair Memory Corsair VX 550W Ultra Quiet...
System failed to boot when installing additional 2X 1GB RAMs.
you need to place them on your motherboard where the memory is installed. Place in the order of one new, one old, one new, one old stick. that way they run in dual channel.
Oct 07, 2008 | ASUS M2N-E SLi Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Unaible to upgrade RAM
It will only support up to 2GB Ram and the same memory specification
Nov 23, 2007 | ASUS M2N-MX Motherboard
Acer Veriton 6800 PC Desktop Logo
294 people viewed this question
Ekse
Alun Cox
