I lost the manual I need instructions to program it
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER
INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER
INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off,
the code was entered correctly. If the device does not shut off, repeat steps
3-4, using a different code.
Automatic Programming
With automatic
programming, the remote control tests all the codes available on the Code List and assigns the correct
code for the selected device.
1. Turn
off the device with which you want to use the remote control.
2. Press and
hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or
AUD) until the POWER INDICATOR illuminates. The remote control is in
programming mode.
3.Press and
release power button. The POWER INDICATOR flashes once and stays on
indicating the
unit is in Power Scan mode.
3. Press
CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK
to store the code.
5. Press any
other button. If the device responds, the remote control has been programmed.
If the device does not respond, repeat steps 2-5.
Thank You
