Question about EliteGroup P4M800-M7 Motherboard
Motherboard gave 3 beeps
My motherboard gave 3 beeps after i uninstalled the ram and install again. After i installed the ram i smelt some smell. Now however i install the ram motherboard still give 3 beeps (64k ram failure). Any one experienced this before ? Can help me out ?
  • 1 more comment
  • frey88 Aug 19, 2007
    thanks for your solution but i already bought same brand ram and installed but still gave me same problem...
    Sorry for that, the motherboard is using AMI bios
  • Anonymous Mar 12, 2014
    I would like to know what is the maximum amount of RAM memory possible on this motherboard
    Problem Solver:
  • 16 Answers
Hi, u havnt mentioned the bios used by this motherboard. i searched for the bios on the net, but couldnt find. the error beeps depends on the bios used by the motherboard. usually 3 beeps(2short and one long) means, the video card is damaged.
Posted on Aug 19, 2007
    Novelist:
    Champion:
  • 231 Answers
Hi, it sounds like your Ram was not seated fully the first time and has damaged the contacts. Get another stick of RAM and install that making sure it is fully seated and then try again Regards mistyman
N15235 Foxconn- when i switch the pc on everything works except there is no screen
First step, pull the RAM (all of it) and see if you get the 3 beep issue again. If you do, install one stick of memory and see if the computer comes on. If not change that stick for another, and repeat untill the computer boots or you have tried every stick of RAM. If you have tried every stick of RAM try a different slot, and repeat one stick at a time. If when you have all the memory out of the computer, it does not do the 3 beeps, then you have a possible power supply issue, or some type of damange to the motherboard. Damage to the motherboard would include but not be limited to; static discharge during cleaing or memory installation. Cable beining lossened during the process (easly fixed by making sure all cables are snug). Resistor or other component lossed or detached from motherboard.
I have included everything I could think of here. If during the steps above you find more information, please provide it and I will try to point you in a different direction.
Jun 17, 2012 | Computers & Internet
My cpu is making 1long beep and 3 short beep sounds and not restarting.
This POST beep code usually means a RAM problem.
Try reseating your RAM module/s and reboot your computer.
Try the BIOS setting and check the RAM size, does it match the total installed RAM.
If you suspect the RAM is faulty, remove the RAM module/s and take it to your friendly computer repair shop and get them to test the RAM for you.
Jan 20, 2012 | ASUS M2N-MX SE Motherboard
1st question== my friend gave me a p4vmm2 v8.1 mobo but when i turned it on it making a long one beep sound simultaneously inside ! there is no ram inserted! Is that the problem?????????? 2nd...
that's a functional motherboard you got there. The beep that you hear is an error beep for not reading a ram. Yes, you will insert a ram that is compatible with your motherboard. No you can't use that without a video card. If you've got a spare video card put it on your motherboard
Aug 02, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
I HAVE INTEL DG31GL MOTBOARD I HAVE ONE PROBLEAM IN MOTBOARD IS NO DIPLAY ONE SINGNAL LIGHT IS GLOW
Hell Krishna,
The display problem is common in all the Intel DG31GL motherboard. Please switch off the computer first. Then remove the Li-ion cell/ battery of the mother board. Replace it with new Li-ion cell/ battery.Also remove the ram of the motherboard. Insert the cell/battery in the motherboard and switch on the computer without installing the ram. After 2 to 3 beeps switch off the computer and install the ram and then switch on the computer. The display will come again.
Jun 01, 2011 | Intel Motherboard
MSI H55M-P31 board & having 2 2GB DDR3 modules and I7 Processors, installed memory on dual channel and sytem beeps 3 time and no display
Depending upon which BIOS make is installed in your computer, 3 beep means RAM fault.
Check the specification of your motherboard for the recommended RAM.
Reseat the RAM nodules in the motherboard.
Remove the RAM and get them tested at your friendly computer repair shop.
Sep 24, 2010 | MSI H55MP31 LGA 1156 Intel H55 Micro ATX...
Long beep and continue acer motherboard N1996.
1. Beep codes indicates that there is some problem with your RAM memory sticks installed into your computer motherboard.
2. For detailed information about the beep codes, refer your motherboard user manual as there are different kind of beep notifications for different problems.
3. Try removing the RAM from your motherboard, clean of any dust, replace it back to the motherboard and try starting your system. Repeat the step for atleast 10 times, until your system starts up.
4. If still the problem, persists, try replacing your RAM and try again as this will help us to find out if the problem is with RAM or not.
I hope this is helpful to you.
Please rate the solution provided.
Thanks
Jun 29, 2010 | Computers & Internet
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
3 beeps on boot no screen and boot stops
sounds like the motherboard trying to give you an error code. search beep codes for the type of motherboard you have and then you will get a possible cause of the interruption.
my friend once gave me an old ibm that had a beeping sound preventing it from booting. i googled ibm beep codes and learned that it was a video card error. i swapped the video card and problem solved
Jul 23, 2009 | Intel D850MV Motherboard
Motherboard is dead
remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
May 31, 2007 | Intel SuperMicro SUPER Motherboard - 810...
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
206 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
