HP HP 2133 Mini Notebook PC + Logitech Z-10 Speakers
Problem for HP HP 2133 Mini Notebook PC + Logitech Z-10 Speakers
Keyboard letters 'm,j,k,l,u,i,o' permanantly
By newsam11 on Mar 22, 2009
keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
Best Solution
posted on May 17, 2009
Very Helpful)
aspmanuk
Rank: Apprentice
Rating: 100%, 1 votes
This worked on my Dell Latitude
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 22, 2009
Very Helpful)
tjproko
Rank: Master
Rating: 92%, 10 votes
There are F key for toggleing and locking in the Numeric keypad that doubles as your alpha numeric board needs to be released. This is usually a combination of keys which share a similar color.
4 Using the keypads
The computer has an embedded numeric keypad and also supports an optional external numeric keypad
or an optional external keyboard that includes a numeric keypad.
Component Description
(1)
fn key Executes frequently used system functions when pressed in
combination with a function key or the esc key.
(2) Embedded numeric keypad Can be used like the keys on an external numeric keypad.
(3) num lk key Enables the embedded numeric keypad when pressed in
combination with the fn key.
8 Chapter 4 Using the keypads
Using the embedded numeric keypad
The 15 keys of the embedded numeric keypad can be used like the keys on an external keypad. When
the embedded numeric keypad is turned on, each key on the keypad performs the function indicated by
the icon in the upper-right corner of the key.
Enabling and disabling the embedded numeric keypad
Press fn+num lk to enable the embedded numeric keypad. Press fn+num lk again to return the keys to
their standard keyboard functions.
NOTE: The embedded numeric keypad will not function while an external keyboard or numeric keypad
is connected to the computer.
Switching key functions on the embedded numeric keypad
You can temporarily alternate the functions of keys on the embedded numeric keypad between their
standard keyboard functions and their keypad functions by using the fn key or the fn+shift key
combination.
● To change the function of a keypad key to keypad functions while the keypad is off, press and hold
the fn key while pressing the keypad key.
● To use the keypad keys temporarily as standard keys while the keypad is on:
◦ Press and hold the fn key to type in lowercase.
◦ Press and hold fn+shift to type in uppercase.
Using an optional external numeric keypad
Keys on most external numeric keypads function differently according to whether num lock is on or off.
(Num lock is turned off at the factory.) For example:
● When num lock is on, most keypad keys type numbers.
● When num lock is off, most keypad keys function like the arrow, page up, or page down keys.
To turn num lock on or off on an external keypad as you work:
▲ Press the num lk key on the external keypad, not on the computer.
This is from HP's documentation, but it is similar to my Toshiba
Peace,
-t
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
Very Helpful)
ae_7fam
Rank: Wiz
Rating: 76%, 33 votes
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Was this helpful?
Yes
No
Solution #4
posted on Sep 17, 2009
Not Rated)
danigirl7969
Rank: Apprentice
Rating: 0%, 0 votes
if you are getting numbers when hitting letters on the 2133 you need to press shift+fn+num lk simutaneously and this will turn off number lock and make your letter keys work again.
Was this helpful?
Yes
No
Popular Solutions for HP HP 2133 Mini Notebook PC +
Questions and Unsolved Problems for HP HP 2133 Mini Notebook PC +
Do you recommend HP HP 2133 Mini Notebook PC + Logitech Z-10 Speakers?
Answer
Answer
cannot install conexant ac-link drivers
Answer
I have a HP PSC 1510 ALL IN ONE. EVERYTIME I TURN ON THE PRINTER IT MAKES AN ALIGNMENT COPY. hOW CAN... (More)
Answer
labtop acer aspire saya LCDnya terkena air. bagaimana cara menghikangkan air yang berada dalam LCD... (More)
Answer
Dvd drive wont work
Answer
DPI Scaling Control Panel is not going back to Larger scale (120 DPI to make it readable) after I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP HP 2133 Mini Notebook PC +...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
