Question about Canon ZR85 Mini DV Digital Camcorder
Video to pc problem
Ok so I have the cam and the usb port to connect it to the computer, but for some reason it dosn't read the video transfer, but ?I can transfer pictures...whats wrong?
  • 31 Answers
Usb port on this camera used for picture transfers, but to transfer videos, use FireWire DV cable, can be bought on ebay for a buck or so
Posted on Aug 20, 2007
SOURCE:
How do you move video images from camera to pc?
It has USB port, so just copy the file over while you connect it to your computer with a USB cable, make sure your computer supports USB ver2.0 or above, to get the fairly good speed of file transferring speed.
You may need to install the driver/applications that came with the camcorder to get the recorded videos and pictures copied to your pc.
you can find the introduction manual here, http://resources.jvc.com/Resources/00/00/91/LYT1591-001D.pdf
Sep 09, 2011 | JVC Everio GZ-MG21 Camcorder
I have a samsung VP-D70 camcorder and I want to transfer data to my laptop. The DV out on the camcorder is descibed as 4 pin the other end of the cable supplied is not usb (it has 723 on the connector).I...
This is a Firewire cable, also known as DV or IEEE 1394. Sony call it i.Link. It is not compatible with USB and you cannot get a lead to connect it to a USB port. There are converter/adapters that are supposed to allow Firewire to connect to USB but many forum posts say they do NOT work for video transfer. Unfortunately, most Mini-DV cameras will not transfer video by USB cable, even when they have a USB connection (it is usually only used for still pictures).
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you had a desktop PC, you could fit an add-on Firewire interface card to the expansion bus. This will come with a driver for the card.
I have a Samsung Mini-DV, and do transfers with it to the one computer I have that has a Firewire port. It is the only thing I use that computer for, and the reason I haven't thrown it out.
Jan 16, 2011 | Samsung VP-D70 Mini DV Digital Camcorder
Aiptek camera transfer to cumputer
Using the PC Camera Function
1. Installing the AF Cam driver
You need to install the AF Cam driver before using PC Camera
or video conferencing function.
* If you have already installed the AF Cam driver, skip step 1. "Installing the AF Cam driver" and go to step 2. "Connecting your camera to your computer".
2. Connecting your camera to your computer
2.1 Turn on your computer
2.3 Insert the USB cable to the USB port on your computer
2.4 Insert the other end of the USB cable to the USB port on your camera.
* Then you can see the camera as removable disk. You can transfer the pictures from your camera to your computer like transfering files from one folder to another.
1. Go to camera folder
2. Select the file/pictures you want to transfer then right click and choose move option (if you want the files to be moved on your computer) then choose the desired target folder or drive.
*you can just copy the files form the camera to your computer too.
select the files that you want to copy then right click, choose copy then paste on the desired folder or drive.
Apr 09, 2010 | Aiptek PocketCam 3M Digital Camera
I want to transfer a video tape made on my Sony DCR-TRV285E camcorder to my laptop where I want to view the video. My first problem is that I don't have the necessary USB cable and the second problem is, I...
A lot of people have had problems with this. You will need either a usb cable or firewall cable to transfer the videos to the computer. It looks like it works all right with a Sony Vaio computer, but people are reporting problems trying to import the videos to other computers. I didn't see anyone with a solution, per se, so I would contact Sony to see what they have to say. As far as the usb port on the cam, I've never owned one, but have read about references to it in reviews, so it must be on there somewhere. Wish I had more info for you, but it looks like this is a big problem with this model cam.
Apr 02, 2010 | Sony DCR-TRV285E Digital-8 Digital...
How do i copy recorded video unto my computer
Add a firewire port to your computer and get that working. Then, using a firewire cable connected to the DV port of the camcorder (not USB), you will connect to the firewire port you just installed and import the video.
USB is used only for transferring stills from the memory card or maybe using the camcorder as a web-cam.
To get the video off the miniDV tape, you need to use firewire (IEEE1394a, i.Link... all the same thing).
Mar 19, 2010 | Panasonic NV-DS65 Mini DV Digital...
DCR-TRV355E Sony Handy Cam not recognizes by Vista o my 32 bit HP lap top (New)
If you are using the USB cable to connect the Camcorder to the Computer to transfer the videos to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer.
The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video to the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!
Oct 19, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Usb handy cam is invalid when i connect my camcorder to my pc
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.(An i.LINK is a black D shaped connector with 4 or 6 pins. The type ofcable to be used will depend on the i.LINK port of your Computer. TheSony Camcorder will have the 4 pin i.LINK cable and if the computer hasthe 6 pin i.LINK port, then you may have to use the 4 pin to 6 pini.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE:As the Camcorder does not support USB streaming with Vista, it is notrequired to use any Sony Device Driver to transfer the video to theComputer. You do not require any Drivers or Software from Sony totransfer the video from the Camcorder to the Computer using thei.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
Ifyou are using a Windows XP Operating System then you have to installthe USB Streaming Driver in the Computer from the supplied Softwaredisk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
NOTE: If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Oct 01, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
May 17, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
No driver for Canon FV M200 camcoder
Are you connecting to the camera with a USB cable? Many camcorders will not allow you to transfer video over the USB interface. Video transfer often requires a Firewire connection and software. You'll need a Firewire cable (sometimes called a DV cable).
If you computer is reasonably new it most likely will have a Firewire port. If not, you'll need to install a Firewire PCI card.
The software I use is called Scenalyzer. There are other options, but Scenalyzer has a free demo you can try. You can download the software here:
http://www.scenalyzer.com/
The demo software is fully functional, but it will leave a watermark on your video.
Good luck.
Dec 09, 2007 | Canon MV700 Mini DV Digital Camcorder
How to download video from panasonic nv-gs15 to Computer
I connected with USB and used MS Movie Maker. The sw that came with the camera only transferred still pictures.
Oct 02, 2007 | Panasonic NV-GS15 Mini DV Digital...
Canon ZR85 Mini DV Digital Camcorder Logo
233 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
