Question about Sony KP-61V90 61" Rear Projection Television
HD??? I know this is not HD built-in, or ready, or capable, etc...but I was told that I could purchase a converter for this TV so I could make it an HDTV. Is this correct and if so, what equipment would I need and where and how could I get it? Thanks.
  • RFK17 Sep 09, 2007
    Will a HD Box from my cable provider do the same thing?
    Sergeant:
    Champion:
  • 375 Answers
Rca makes a table top box.
Posted on Sep 08, 2007
Just purchased polaroid TLAC-02255. when i scan for channels on both the tv and converter box it never picks up fox, pbs, or kgw. all channels i could get on my old tv with the converter box. how do i fix...
Not a solution...but an "answer". First, you should call the tech support number and talk to them; but others have posted on this site (and I'm about to) that they're having the same problem (mine won't get cbs or abc stations). I was told, as was another poster on this site, that 'some tvs just don't tune into some stations).
Even though the tvs have built-in ACTS and a NCTS tuner (for analog and hd) they don't always work with external (rabbit ear) antenna.
ANother poster to fixya wrote that she's returning her set to Target...where mine was also purchased. I'm going to ahve to box up ours also and return it, a shame since it was a gift!
Jan 01, 2011 | Polaroid LCD-1750 17 in. HD-Ready...
Hitachi 53UDX10B HD Converter
In the USA, "HD Ready" refers to any display that is capable of accepting and displaying a high-definition signal at either 720p, 1080i or 1080p using a component video or digital input, and does not have a built-in HD-capable tuner.
With that said your unit can display HD but does not have a HD-capable turner. You will have to have a converter box to obtain this for over the air channels. If you have any other source that can give you a HD singal (cable some DVD's, blu ray)your unit can display it. Hope this info help's.
# NOTE - If this info was helpful to anyone please click on yes!
Jun 09, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
I have HCL5515W tv. Want to convert to HD tv.
Not without the box, HDTV didnt really made an appearance except in the past 5 years
Jan 18, 2009 | Samsung HCL5515W 55" Rear Projection...
Convert my Sony kp61hs10 HD Ready to receive HDTV
no need to convert ,,i have same tv,,hdready just means it has no built in converter. You just need a HD converter box or a cable box or dvr that is also an HD receiver.
Dec 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
SYLVANIA 6620LG TV - DTV??
The ;quick answer is YES, you will need a converter box to receive digital broadcasts. This set has only an analog tuner built-in. That is why it is HDTV "ready" (ready for you to add a tuner).
As for HDTV vs EDTV it is a matter of resolution. Your set is capable of EDTV resolution, which is better than SDTV (standard definition TV) but not quite as good as HDTV. With a digital tuner you will be able to view all digital programming, even HD, and it will look excellent, though not quite as sharp as a set with higher definition.
Feb 14, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Sony KP-61V90 61" Rear Projection Television Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
