2003 kawasaki KX 125 Logo
Anonymous Posted on Jun 06, 2013
Clutch problems I was riding my dirt bike one day and was coming up to a stop I pulled in the clutch and nothing happend, it didn't release. The cable is not broken. what is the problem?
Anonymous
Level 2:
Sergeant:
  • Expert 339 Answers
  • Posted on Jun 08, 2013
Anonymous
Expert
Level 2:
Sergeant:
Answers
339
Questions
0
Helped
84750
Points
594
Release arm in engine is broke.
5 Related Answers
onyeredson
Paul W
  • 404 Answers
  • Posted on Jan 21, 2009
SOURCE: 1991 Kawasaki KX 250 super tight clutch
Hi!
Help is at Hand (Excuse pun),
This problem described strongly relates to a seizing clutch cable or frayed.
If you remove it try and pull/push the inner with your fingers there should be No resistance, you may get away with a good oiling but I would recommend replacement.
Good Luck!
Paul 'W'
Onyer~EDson(:0) {#><
Please remember to politely rate my effort!
kvcmptr
Kevin Reaver
  • 8 Answers
  • Posted on Jan 26, 2009
SOURCE: Clutch slipping while cold, when warm/hot, it operates great.
I have a 2000 Vulcan Nomad FI & had a very similar problem. In fact, it's a very common problem with these bikes. I fixed it by replacing the Clutch Spring. (As Described here: http://www.gadgetjq.com/clutch_spring_replacement.htm
It cost me $40 and 3 hours of time with an impact wrench.
Anonymous
  • Posted on Mar 15, 2009
SOURCE: 2003 KX125 Clutch Problem
have you checked the basket for groves? if it is groved the plates will stick the release all of a sudden.
tombones
  • 3567 Answers
  • Posted on May 03, 2009
SOURCE: when i pull the clutch on my dirt bike it doesn't
First, get a new clutch cable. Tape the new cable to the old one and unhook the old one. Now you have a new cable and a reserve cable ready for use if needed during a race.
Second, change gearbox oil and install a new oil filter if your bike has one. All the dirt and grit in the oil is binding the clutch. Ride the bike for a couple of hours using the clutch often. Now drain the oil again and put in fresh oil. This will flush out the dirt and grit. Use 10w40 motor oil. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
Anonymous
  • 115 Answers
  • Posted on Jul 05, 2009
SOURCE: my dirtbike clutch doesnt work right
Make sure that the cable is still working and hasn't broken from freezing up since it was parked. Had the clutch been causing any problems in the past? This clutch is not adjustable at the base where it mounts to the engine. Adjust the cable if needed from the handle. If this doesn't help, then it sounds like an internal problem. This would require taking off the right side of the motor. Just get a new gasket, and a clutch kit. The basket might be able to be saved with emory cloth. You can get a clutch kit at bikebandit.com
Bike jumps when on release of clutch in first gear and stalls
The clutch plates are probably rusted. I ride the bike with the clutch lever pulled in until very warmed up and keep blipping the throttle at low speeds in first gear this sometimes releases the stuck clutch.
Jan 12, 2014 • Motorcycles
1982 Honda cb450sc Nighthawk. Just bought. First bike. Was riding it this morning everything was fine then after around an hour I felt that when I pulled in the clutch to stop and then wanted to take off...
It appears the you have a clutch pressure plate problem in that it is slipping and overheating to fade condition. Check for oil level as most bike clutches run in oil. Check clutch cable adjustment. Check cable for kinks and split wires.
Apr 27, 2013 • Motorcycles
2answers
2008 Ducati S4RS dry clutch either sticks or doesn't disengage when I pull the clutch in riding, and sometimes I can't get the bike out of gear unless I stalling the motor while in gear.
Check to ensure the hydraulic mechanism is working properly and hasn't leaked. If it has leaked or there is air in the system, it wont allow the clutch to disengage properly and would be akin to a clutch cable being out of adjustment or broken. If the yydraulic release is working as it should be, you may have oil fouled clutch plates. Oil fouled plates would cause the bike to jump/lurch from a stop and could also stick together.
3helpful
I have problem with my clutch in my 2004 Susuki Intruder. I put it away last year it was working fine I went to take it out and the clutch does not work it will go into grear but the clutch wont disengage
G'day. I can definatly help you with this.This is a problem I have come across many many times in my career as a motorcycle mechanic.It is a very common problem for bikes that have been sitting around for a while.What has happened is that all the clutch plates are stuck together. There are two ways to rectify this problem.One is to remove the clutch cover, remove the clutch springs,then the plates-noting the order- clean, re-lubricate & re-assemble.
The other way- which I have sucessfully used in 98% of cases is to start the bike in neutral,chock the front wheel- I position the bike with the front wheel against a brick wall or good size tree for a dirt bike,hold on the front brake tightly,rev the engine & hold at about 2000 rpm,click it into 2nd gear.CAUTION- The bike may jump forward &/or stall(get some friends/helpers on each side as "catchers" if your not too confident) Try this a couple of times if necessary & it usually works. Also you could try riding the bike with some front brake applied whilst pulling the clutch lever in & out several times.(This seperates the pressure plates whilst the clutch basket is spinning & can let the oil acess the fibre & steel plates whilst there not under pressure).
I hope this helps you.
Kind regards Andrew Porrelli
1helpful
When i pull the clutch on my dirt bike it doesn't spring back and when it's pulled the clutch doesn't engage.
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
