Question about Dell 922 All-In-One InkJet Printer
Carrier jam The printer will not print and makes a very loud shrieking noise when turned on or off. The error message on the printer says "Clear Carrier Jam". This happened after a paper jam. The carrier does not move, it shrieks, possibly because it is trying to move and can't.
    Scholar:
  • 76 Answers
Two solutions for you: 1)There seems to be a coating on the metal rod that the cartridges travel on. See it back there? With the power disconnected, wipe this rod with a kleenex and the problem seems to go away. It presents a drag on the cartridges and causes the problem. You might have to GENTLY forcibly slide the cartridge a bit to each side to finish cleaning the rod. ONLY DO THIS WITH THE POWER OFF!! 2) Or you can also turn off your printer, then slide the cartriges all the way to the left, and GENTLY wipe the encoding strip running right behind the cartrige carrier.(it will look like a translucent piece of plastic strip in most printers). Wipe it down with a soft cloth gently, then slide the cartriges all the way to the right, and repeat this process. When you are done, simply close the cover, power back up, and see if it will print a test page for you. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
SOURCE:
Printer made machine gun noise. will not print.
The print head is stuck - something has jammed it and the noise you are hearing is the carriage for the print head. Open the top and try moving the head by head sideways to see what has jammed it.
Aug 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
When trying to print, it says I have a carrier Jam.
HI!! in your case my diagnose is that maybe the the incoder strip was defective and need to replace it.
Jul 12, 2009 | Lexmark P4350 All-In-One InkJet Printer
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Carrier jam
your encoder strip(a transprent strip behind the carriage) is either broken or loosed up and so it is not able to get self aligned.kindly fit the encoder properly or change the encoder if neccessary.encoders are usually very cheap.wish u luck!!
Apr 28, 2008 | Lexmark P4350 All-In-One InkJet Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 944 All-in-One Printer - printhead carrier jam
I just found that one of the little feeder rollers (??) on the roller bar has jumped out and is sitting (still attached by its spring) on top of the roller bar. I reckon that's curtains for the printer. Am I right or is it repairable?
Nov 25, 2007 | Dell 924 All-in-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
136 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
