Question about Hitachi CLU-5713TSI Remote Control
The front panel digital array button
The left side of the screen is off and in order to fix it we have to hit the array button to start the aligament system
  • lucky13-22 Nov 28, 2007
    My tv is way off on the left and right side but the center is perfect and i ajusted the array and nothing the crosses in the middle are near perfect and the left and the right are way off .i was woundering how to fix this and it seemd my red projector has a little black line on the top part of it .could their be a reste botton that i could press that will make it all perfect ..or do i need to get down and work on it...i can do electic repair so ia am not an ideot so can i get step by step instroctions to fix this,i have never really worked on projecton tvs.
  • 398 Answers
There should be a little door directly under the center of the screen and behind that door should be the button you are looking for. On the older Hitachi projection sets a large white cross will appear on the screen when that button is presses and you will only be able to adjust the center of the picture. The newer sets will automatically converge themselves (called Magic Fucus) when that button is pressed. Follow the instructions in your owners manual for convergence and let me know if you need more help.
Posted on Aug 19, 2007
SOURCE:
No picture
Try unplugging for 15mins then hold power button if nothing then TV is probably pooped out if plasma screen then the backlight bulb probably blew out usually located in front left hand side behind panel in a plastic and metal cage you have to order these from the company
Feb 14, 2015 | Televison & Video
Chrysler sebring conv won't start, headlights flicker
The first thing you do is have the battery and the battery cables checked, it sounds like a dead battery to me. The battery is accessed through the drivers side front wheel well through an access panel. Remove the front left wheel first.
Aug 23, 2012 | Cars & Trucks
I hit a deer with the front of my 1993 splash and it shut off and wont start now
You will need to reset the fuel shut of switch, this is setup to shut fuel off in a crash or impact, all you need to do is locate it and push the button down, the button is located on the top of the switch and use finger to push it and then restart the truck.you will need to look on both sides of the truck, start at the driverside left kick panel this is the panel that your left foot would hit if in the driver seat, its the side panel on the floor area check for a hole or look behind the panel if its not there look in the pass/side panel good luck, good day
Mar 27, 2011 | Ford Ranger Cars & Trucks
HAVE NIKON D40 THE LARGE MONITOR AT BACK OF CAMERA HAS BEEN TURNED OFF SOMEHOW HOW DO I TURN BAK ON????
turn on your camera
press the menu button on the back og the camera
using the switch to the left of the screen, hit the left side once to move the screen cursor to the small icon on the left of the menu screen that looks like a "penci".
now click the button to move the highlight back to the right side then move up or down to select "07" Image Review.
hit the 4 way button on the right side to show the two options, on or off.
move the highlight up or down to select the one you want (assuming you want "on"), then press the center of the 4way button, "OK". now when you shoot a picture it will show up on the back screen until you touch the shutter release button again.
Dec 27, 2010 | Nikon D40x Digital Camera
The picture on my rear projection tv has an hour glass appearence. Both side of the picture are curved inward towards the center of the screen.
Hi , i will suspect your convergence board is defective you have 2 ic call stk for convergence correction and pin cushion
and some low value resistor and different bad soldering ,all this needs to be replaced and then reajust ,you must have a digital
array button on the front panel button some an automatic set up call majic focus wheres you must be able to realing this but if you dont have this button is probably locate on the convergence board anyway the circuit needs to fix befor any attempt to make any adjustement ,you may need a tech to do it, ic cost about 20 box each theres two on the board and s its an hour jobs about , depend on the tech experience...
hope that will help
regards Alan
Nov 01, 2010 | Toshiba 57H81 57" Rear Projection...
Can not line up the red digital array crosses along the left side of the tv screen
Same thing happened with mine, tried to fix it myself with no avail, called a repairman, $300 to fix.
May 09, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
My Vizio 37' flat Screen TV Closed Caption wont turn off
If you have a digital cable box, turn off the box but leave the TV on. Hit the "Menu" button on the front of your cable box and a setup menu should come on. Use the cursor buttons on your box's front panel to go down to the "Captions" option, which is probably set to "Enabled" and hit the right or left cursor button to change it to "Disabled." That should solve your problem.
Dec 29, 2008 | Vizio L37 Television
Sharp al2030 error code h4 upon power up
Here is the solution straight from the lips of tec support at sharp.
This can happen due to a power outage.
Here is how you fix it.
1. Hit clear, then auto. (clear is on the right the red C, auto is on the far left)
2. Once again Hit clear, then auto. (clear is on the right the red C, auto is on the far left)
At this point wait for the screen to go dark.
3. Type in 14 (hit the 10 once an the 1 button 4 times)
4. Hit the Green Button.
The screen will go dark and reset the copier.
Jun 12, 2008 | Office Equipment & Supplies
Problem continued
Good Day;
When you activate the Mj focus the TV is restoring the data from the TV's digital circuits. So, you have the ability to change the IC's you can do this.
You need to go into the con service mode. Take off the front grill, remove panel, 6 - 8 screws. From the front there is a switch on the left hand side, it is small, white button with TV on. now you are in the service mode, using TV's remote adjust. Make sure you save dat. Go hit on line site get more info.
Goo0d Luck!
May 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Problems with digital array
Aloha, did you get this resolved?? I have the same problem as you. Did you get your fixed?? If so, any information would be awesome. Thanks, [email protected] Thanks Bryan
Jan 10, 2007 | Hitachi 50GX20B 50" Rear Projection...
Hitachi CLU-5713TSI Remote Control Logo
947 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
