Question about Alfred Publishing Teach Yourself To Sing (0-17153) for Mac, PC
Acer AL1715 Screen keeps going blank when booting up- after pressing two or three times it eventually works and then is ok all day!
Sorry - What were U pressing 2-3 times??
Posted on Aug 19, 2007
SOURCE:
Can t open my dell inspiron 1440 old one
For its time it was a good spec with Vista 64 and 4GB RAM and should still work well today. Three options.
1. Try logging into the administrator account in safe mode.
Start your PC and press F8 repeatedly before Windows loads to open Vista's Boot Options screen.
Select Safe Mode and press Enter.
On welcome screen choose the Administrator account, which by default has no password. Just hit return.
Goto Start / Control Panel / User Accounts and create a new user account with admin privileges
Close and restart PC and log into the new account.
2. Use a password recovery program
The following link shows 8 free password recovery programs.
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
3. As a last resort reset to factory defaults. Dells normally come with a hidden recovery partition.
Either boot from the recovery disks you created or use the hidden partition for a fresh install.
To do a factory restore,on startup press Ctrl + F11 which will take you to the recovery partition so you can do a factory restore. This will then create new user accounts.
Good Luck
Jul 08, 2014 | Dell Inspiron Laptop 1440
I can't enter cmos althouh i press del or f2 when i press del ,next screen appear blank with cursor. will this problem solve by upgrading bios?
Restart your computer do you see prees f2 or something else
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Jul 03, 2011 | MSI PM8M-V Motherboard
PC RUN normal: the configuration BIOS STOP and message is: configuration is ok! Problem upgrade failed! use F1 for setup continue or F2 for chancer manual setting DATE/TIME.Thank you.
or
Also you might try
hope this helps
May 08, 2011 | Computers & Internet
When i try to boot windows it seems to boot then i get a screen that says installing cleanup and it has stayed for 3 days now at 48/49
3 days? I would say there's a problem.
Boot into safe mode (pressing F8 repeatedly every half seconds after switching on.
Choose 'safe mode' from menu.
If OK, you'll know it's not serious.
Try again.
If still same thing, go into safe mode again but remove programs that load into memory at startup.
Go to 'run'.
type: MS config
Go to: Boot tab.
Take tick out of anything you don't trust, one item at a time and keep retrying.
Once it works OK, leave the tick out of that box.
Jan 08, 2011 | Acer Aspire One D255-2670
Power on emachine T6420 and moniter is blank. The moniter soon loses contact with the computer. The fan run and power is OK there is no beep code.
If you mean after the computer performs the self test the screen goes blank and stays blank, eventually turning off you are having a hard drive problem. When the computer boots you should see an E-Machines logo and/or a self test on the screen. That is done by the motherboard as part of every boot up. After that the motherboard passes control to your boot device and loads your operating system. If your computer stops booting at that point, your boot device is not working properly. That could be caused by many things - virus, hardware failure, power outage. If you really mean you see nothing at all on the screen when you press the power button your computer simply is not working at all. Open the case, blow all the dust out of it and reseat all components you can, then try again.
Jun 05, 2009 | E-Machines eMachines Desktop PC
When I boot up I get a blank blue screen. Hard drive is working and audio is working
press alt control delete.
Hit task manager
in task manager go to process
if explorer.exe is started hit end task
go to file new task
type explorer.exe and ok
Apr 19, 2009 | Computers & Internet
My dell gx-270 power keeps shutting down.
hmmm,
Dont worry just boot your computer using Bootable disk or windows installation disk, enter into Recovery console by pressing"R"
type the Administrator password if any or simply press "Enter".
At the command prompt type-"fixboot"
once done restart your computer normally.
Mar 25, 2009 | Dell OptiPlex GX270 PC Desktop
Touch pro screen blank
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
Turn on Laptop gets to desktop with icons then screen goes blank
By "where I want to go", do you mean going on the internet? If all you are getting is a blank screen, then you have the "about:blank" virus. Go here, print out the instructions, and read them well. Then read them again and follow them closely. At one time I had it on a desktop system and the instructions worked just fine.
Dec 10, 2008 | HP Compaq nx7010 Notebook
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Open Questions:
See all Alfred Publishing Teach Yourself To Sing (0-17153) Questions
Alfred Publishing Teach Yourself To Sing (0-17153) for Mac, PC Logo
79 people viewed this question
Top Alfred Publishing Computers & Internet Experts
Ekse
Alun Cox
Are you an Alfred Publishing Computer and Internet Expert? Answer questions, earn points and help others
