Question about Kenmore 54602 / 54604 / 54609 Side by Side Refrigerator
Kenmore Elite Refig. model 54602300
Ice cubes hang up in out let. Some time a ice cube will fall out on the floor after use. are ice cubes to large?
  • youngman Aug 25, 2007
    The flaper is closing about 3 seconds after the ice has fallen. At times a ice cube will fall out on the floor3 to 5 minutes after use. It seems that the ice cube is wedged up in side untill it melts enough to free itself and fall on the floor. Possable cause could be the ice cube is to large. Is there a adjustment to control the size of the cube?
  • Anonymous Mar 19, 2014
    psb48ysxss
I note your comment not helpful,however there is no cube size adjustment, and the the auger motor that dispences the ice switches off immediatly you remove the container from the ice shute, the flap then stays open for a further three seconds to allow any ramining ice to fall, the only other source of a problem could be the ice bin but this would be extremely unusual, I work on these units daily and can assure you that there can be no other fault. Regards Advisor
Posted on Aug 25, 2007
  • 183 Answers
Problem is due to ice flap closing too quickly, depending on model some have a delay before flap closes, ice should stop falling 3 seconds before flap closes. Regards Advisor
Posted on Aug 23, 2007
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
Oct 08, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite model number 795. my ice dispencer only gives crushed ice even though its set to cube
1st i would remove all ice out of bin, clean outBIN with warm water under sink. put ice back in do not throw away for testing purposes. if worked then a cube may have been caught in bucket chopper improperly . if didnt change anything could be a bad crusher solenoid. in home service could run you 90-145 dollars depending where you live. if you do it yourself crusher dispenser solenoid will run about 30-50 DOLLARS. hope this helps
Sep 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 54602 / 54604 / 54609 Side by Side Refrigerator Logo
227 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
