Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Television Model # WD-52627, Serial # 107108 - TV Not Responsive
The television does not respond when I turn it on with the remote control. It can be turned on and off, but manually. The remote only turns on and off the cable box. The volume cannot be adjusted either by the remote or by doing it manually on the television. We changed the batteries, but was not effective. Whatever the manual says on page 90 of the manual does not work.
    Genius:
  • 1,153 Answers
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Posted on Aug 22, 2007
SOURCE:
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
I bought new universal remout control, we have tried to program this and it doesn't work. The frist problem is that it does not trun Off/ON, unable to change the channels (does not respond to any...
Return the tv universal remote where u bought it,u only used a universal remote when u must have too,because universal remotes are very strangely and react differencely each models of tvs u tries to programming it codes to it CPU chip.Norcent tvs are recent tvs in the market,have many spare original remote.Try website like Remotes.com to buy the tv original remote.
Jun 18, 2011 | Norcent Technologies LT-2723 Television
The TV worked fine last night, but today will not power on from either the remote or the front panel. When I remove and reapply AC power by unplugging the cord, the Power/Timer indicator light blinks...
hello am rico, it looks like you have bad lamp, or bad thermal sensor, go get and hold the buttons menu and input or device, it will blink and then pause and then will blink again check the blinking. like 2 pause 3 or 2 pause 2 for codes. if you need more help, feel free to call at anytime. 602-810-7149.
Jan 07, 2011 | Mitsubishi WD-52627 52" Television
Had a new dm module put in. TV does not show device menu when I push remote.
This set like most of them has a reset--yours has a soft and a hard reset----try the soft reset first--
(with set on) Menu, 1,2,3 enter.
Let me know what happens.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WD-52627 52" Television
Where is the ballast board on a Mits. WD-52627
In order to reach ballast you have to remove optical block. Ballast is usually covered with metal shield. It's located on the right hand side of optical block (if to look from the back of the TV). and it have two black thick short wires that connected to the lamp cartridge socket.
Regards.
Russ.
Aug 12, 2010 | Mitsubishi WD-52627 52" Television
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
How do I turn up volumn on the wd-65735 model without remote. it only goes up to 63 and my remote is broken so I need intructions on how to do it manually.
open mitsubishi front door see volumn control push button use +/- if you need new remote part no: Manufacturer Mitsubishi Part Number 290P123010 Description REMOTE
Dec 06, 2009 | Mitsubishi WD-65735 Television
Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
