Question about Princeton Digital VL180 18.1 in. Flat Panel LCD Monitor
Missing ribbon wires
I have a princeton vl180 monitor which is missing 2 ribbin wires (never had them, bought it hoping i could get replacements). they seem to b about 7/8" and 1.5" respectively, i don't know how long though. they seem to cross like an 'X' from origin to destination, and said crossing would look like a rubber 'X' folded horizontally. is there somewhere i can purchase replacements for them? the gent i bought it from hunted for them and couldn't find them after he sent me the monitor. he had been using the panel alone without the stand frame in some application, then the need was negated, so he sold the monitor. one receptor 'socket' has '30' at 1 end and 'G' at the opposite end. the other receptor 'socket' has '45' at 1 end and 'A' at the opposite end. all without the quote marks (i hope this info is of some help)
  • Princeton Di... Master
  • 17,162 Answers
There is no chance of getting parts for that model of lcd. It is obsolete.
Posted on Mar 17, 2017
tantong
  • 138 Answers
SOURCE: Princeton Monitor VL1917 - No Power
This is the way how to examine what's wrong with your LCD monitors. After you turned your pc on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
  • 20 Answers
SOURCE: will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Posted on Mar 27, 2008
  • 4 Answers
SOURCE: Can changing 3 capacitors on motherboard solve my problem?
We had a power surge and my VL2018W LCD monitor stopped working... blank screen and flashing blue light.
I carefully opened up the back and found the power board (the one the AC plug goes into). There were about 5 electrolytic capacitors that were bulging (but not ruptured). There were 3 with the values listed by the original poster (470uF @ 25V) and 2 with 1000uF @ 10V.
I scrounged a couple of 2200uF@10V caps for the last two and bought 3 470uF @ 35V caps from Radio Shack (P/N 272-1030).
Luckily, the monitor came right back up and seems to be OK. It was out of warranty, so there wasn't a big risk.
Just increasing the working voltage won't do that much for you. If any caps are bad, just replacing them with the same value is good enough, but a higher working voltage won't hurt (usually means a bigger cap).
Good luck.
Rich
Posted on Jul 22, 2008
budmrtn
  • 11361 Answers
SOURCE: I reset the resolution on the computer (big
Boot up in safe mode and selct VGA support, then set the video resolution to your Princeton VL2018 native resolution mode (1680x1050 @60 Hz)
See more here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Hopefully you monitor doese not have the same problem (bad caps) just like the other VL2018 as shown in my pictures here (but it will fail for sure later on):
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Posted on Jun 13, 2010
budmrtn
  • 11361 Answers
SOURCE: Princeton monitor VL1918 screen blinks for about
Look for bad caps, transistors, etc.
See my pictures here: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 08, 2010
The power supply for my Princeton Monitor, Model VL1916, S/N WCCE4307992 has gone bad. How do I get a replacement?
THe AC adapter (power supply) for my Princeton VL173 went bad. I discovered it was the PS and not the display by plugging in an old adapter from an HP printer that I had replaced. The input plugs matched and the power out profiles were nearly identical Only very minor differences). It was just a stab in the dark, but it works! Now my display is 12 years old and still going strong. I hope this helps.
Jun 19, 2011 | Princeton Digital Computers & Internet
I reset the resolution on the computer (big mistake) and now I cant see the screen in order to reset it back. The screen turns all blue with two messages and a flash of the windows screen (windows 7). The...
See more here:
Jun 12, 2010 | Princeton Digital VL2018W Monitor
I can not go past 1152 by 864 resolution, the screen will turn off and flicker also now it looks like video shown on the monitor is very high in contrast and sometimes the monitor will be on but no picture...
This means that you have reached the limitation of the graphics card of the PC that you have connected to it. You could try changing the Refresh rate of the card to see if you can get a higher resolution.
Oct 14, 2009 | Princeton Digital VL180 18.1 in. Flat...
Why won't my microphone work on my princeton monitor
are you trying to hook it up directly to the monitor? Not sure that will even work.......
Jul 14, 2009 | Princeton Digital LCD1516 Monitor
When turned on the green on light works and the screen appears and then goes on and off wont steady stay on
Check the Ram in your PC. Refix the Ram. If the problem not solved replace ram by a new one
Jun 27, 2009 | Princeton Digital VL180 18.1 in. Flat...
Monitor goes blank
Sometimes, i can be the wiring, so check all of that. But apart from that. I don't know! Hope this helps!
DigicalJAI
May 21, 2009 | Princeton Digital VL1717 LCD Monitor
PRINCETON LCD-15BLK MONITOR
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
Sep 27, 2007 | Princeton Digital VL180 18.1 in. Flat...
Lcd screen black sometimes
try to change the LCD power settings ... this is a hardware assue ... but i think it will change when u change this settings
Jul 15, 2007 | Compaq (253219-002) Motherboard
Computers & Internet Logo
29 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
