Sunlite Coil Cable Resettable Combination Lock 6' Bike Bicycle Logo
A
Anonymous Posted on Jun 05, 2013
I got my sunlite bike lock only 2 weeks ago and somehow the password I set it to changed on it's own. The first two numbers changed but the last two stayed to what I originally set it to after factory setting. Has this happened to anyone?
1 Related Answer
Anonymous
  • Posted on Aug 01, 2012
SOURCE: Just purchased my sunlite lock
We just got a sunlite lock and figured it out. After it is unlocked with 0000 and the lock opened, the end spins to a "set" position. Set the numbers you want, spin the end back, and lock will be set to those numbers.
Sunlite bike cable lock. I opened the lock and now cant put the male end back into the lock because I forgot the combination
Well, the lock is not any good if you don't know the combination, but for a barrel-type combo lock, if you accidentally turned the numbers while open just push the male end in and turn the 1st ring until it goes in slightly. Then turn the next ring and so forth until it's all the way in. Now you can see the combination.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
2answers
How do I reset a sunlite bike lock?
Is it a key lock? combination with a dial or combination with levers?
Nov 16, 2014 • Cycling
Transmission Problem
Have a bike service center checkout the gearcase. It sounds like it's shot! Especially with the age of it.
4answers
Need to crack my windows vista password
Four steps can help you reset the lost Windows 8/7/vista/xp/2008/2003/2000 password:
Step 1: Download Windows Password Rescuer/Windows password recovery tool on any available computer you have access to.
Step 2: Install Windows Password Rescuer and run it to burn a bootable CD/DVD or USB flash drive
Step 3: BIOS setting of your locked computer to set it boot from CD/USB.
Step 4: Insert the newly CD/USB to the computer.Reset Windows password successfully after Windows Password Rescuer starts.You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows when you can not find target user. With this New user account you can logon your locked computer directly.
More details about the usage:
http://www.daossoft.com/documents/how-to-reset-window-2000-xp-vista-win7-password.html
Trying to install Sunlite HD tourer rear carrier #45772. on a Rand 18 speed. There are no holes for front brackets in frame. Do you just drill the holes?
Never drill holes in a bike frame unless you have a death wish. "Rand 18-speed" doesn't tell us much. Most cheapo bike frames have a 'brake bridge' with a hole on the center for mounting accessories like fenders. Many racks can mount with a single rather than double front supports.. Lacking that, call a bike shop or web search for "bicycle seatstay rack clamps" to adapt the rack to attach to the seat stays.
Sunlite also makes a seatpost rack mount http://www.bikebagshop.com/sunlite-rack-mount-seat-post-clamp-p-1146.html?gdftrk=gdfV22203_a_7c1316_a_7c5544_a_7c11461678151 which looks like a more elegant way to solve the problem.
Sep 13, 2011 • Cycling
1helpful
Just purchased my sunlite lock but the directions where thrown out by the retailer.....how do i set my lock combonation? I have it on all zero's now and it is unlocked...thanks
8answers
Forgot my password
This is simple if you download the SmartKey Windows Password Recovery software make it bootable cd or dvd . And start the booting from this cd and flow the insrrctions on screen you will go to password recovery option and set all the password for administrator and if you get admin pass you can change all use passwords.
Details in:
http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
3answers
The login password does not work, i get a message saying login failed to login, somebody told me to start on safe mode, by pressing f8 and or esc but cant. can someone help me please
I know an administrator tool for Windows password reset, Windows Password Breaker, which can easily reset forgotten Windows password to blank without reinstall. you can have a try.
Or 6 ways for Windows 7 password reset could also be helpful.
2helpful
4answers
I have forgotten what my adminstrator domain password is. Is there a way to redo it or retrieve it?
The best and easiest way to reset the local or domain admin password. Reset domain password with Windows Password Rescuer Advanced. By this small software you can easily reset the domain password without lose anything and do not require any tech operation.
Get to the point, now let us see the step-by-step guide to recover domain password with Windows Password Rescuer Advanced. To recover Windows Server 2000/2003/2008 domain administrator/user password, follow four steps below:
Step 1. Download and install Windows Password Rescuer Advanced and use it to burn a Windows password recovery disk with CD/USB..
Step 2. Set the locked computer to boot from CD/DVD-ROM or USB drive.
Step 3. Boot the locked computer from Windows password recovery disk.
Step 4. Reset Windows 2008/2003/2000 local or domain administrator password by a few clicks.
1helpful
4answers
I just purchased an ee pc and i changed my password now i cant remember it and cant get the system on withoutit
You need to get the password reset from the company itself and its free
Contact:
In order to increase the efficiency of your call, ASUS technical support recommends that you fill out a Case Submittal Form before you call our support center.
510-739-3777 or 812-282-ASUS (2787) - option 3; option 3
FAX: 812-284-0883
Top Sunlite Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Sunlite Cycling Expert? Answer questions, earn points and help others
