Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Fridge is hot while freezer works fine
Hi , fridge is not cooling but the freeze works fine. I cleaned the coils on the bottom , when i open the freezer cold air blows out of the fridge when i close the freezer it stops, i know whave a tub sticking out of the freezer so the fridge gets cool air ,, dont know how long this will last ,, thanks for any help
  • 1 more comment
  • quadfour Aug 23, 2007
    also was told i need a new gasket around fridge not sure if im being taken , ill wait to see if it happens again ,, there was alot of ice build up ,, great advise thanks....
  • Anonymous Mar 23, 2014
    Both fridge & freezer. Only very bottom of freezer works.
  • Anonymous Mar 28, 2014
    Fridge stopped cooling. I cleaned the coils, which were dirty, but still not cooling.
  • 183 Answers
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Posted on Aug 23, 2007
  • Tony Coultrip Aug 23, 2007
    If the door seal is faulty it will allow warm humid air to enter freezer and cause the icing up of the air ways, simple test, place a high powered torch in freezer, close dor and see if you can see any light around the seal edges where it contacts the frame, if not it is ok, if there is then replace the seal asap.
    Regard
    Advisor
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
My maytag side by side is not cooling right.when the weather gets hot and humid the freezer won't freeze anything and the fridge isn't cold enough.when the weather is cooler everything works fine. it is an...
Clean the condenser coils underneath the fridge.
Check condenser fan at bottom of back of ref.
that its not slowed or stopped
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Refrigerators
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
367 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
